[Geoserver-users] WMS application - SOLVED
I can't believe that I've spent almost three days dealing with this simple
issue.
Thank you very much Ben and all others (Stefano, James) who tried to help
me. I hope this will save time for other people in the future.
JJ.
-----Original Message-----
From: Ben Caradoc-Davies [mailto:ben@anonymised.com]
Sent: 27-Jul-15 2:43 PM
To: Jair Santos <jsantos5954@anonymised.com>
Subject: Re: [Geoserver-users] WMS application
Jair,
your service URL is missing the "http://". See the documentation:
http://dev.openlayers.org/docs/files/OpenLayers/Layer/WMS-js.html
Please change "localhost:8081/geoserver/wms" to
"http://localhost:8081/geoserver/wms&quot;\.
Your example worked for me if I put your HTML in a local file and GeoServer
on port 8080. I tested it with the topp:states layer in Firefox 38.
Kind regards,
Ben.
On 28/07/15 06:34, Jair Santos wrote:
Thank you Stefano. That helps.
The answer is yes, I can see the map from this link.
I just can't see anything wrong with code. I pretty much copied and
changed the line to
var wms = new OpenLayers.Layer.WMS( "OpenLayers WMS",
      "localhost:8081/geoserver/wms", {layers: 'Img_Sample'} );
If anybody has any thoughts please share it. I'll try the open layers list
though.
JJ.
From: Stefano Costa [mailto:stefano.costa@anonymised.com]
Sent: 27-Jul-15 1:56 AM
Hi Jair,
can you confirm you can see a map with your layer in the layer preview
page?
http://localhost:8081/geoserver/wms?service=WMS&version=1.1.0&request=
GetMap&layers=Img_Sample&styles=&bbox=-130.85168,20.7052,-62.0054,54.1
141&width=768&height=372&srs=EPSG:4326&format=application/openlayers
If that is the case, it means GeoServer is working correctly and so your
question should rather be addressed to the OpenLayers' mailing list.
Hope this helps,
Stefano
Il giorno dom, 26/07/2015 alle 12.35 -0700, Jair Santos ha scritto:
I am trying to create my first WMS application using the snippet of
code below.
Geoserver is running on port 8081 and I have a web site on port 8080,
both in the same server. When I try http://192.168.1.113:8080/ I
get only the div and a place holder for the image.
Any help will be very much appreciated.
TIA.
JJ.
<html>
<head>
   <title>OpenLayers Example</title>
     <script src="http://openlayers.org/api/OpenLayers.js&quot;&gt;&lt;/script&gt;
     </head>
     <body>
       <div style="width:100%; height:100%" id="map"></div>
       <script defer="defer" type="text/javascript">
         var map = new OpenLayers.Map('map');
         map.addLayer(wms);
         map.zoomToMaxExtent();
       </script>
</body>
</html>
Sent: 22-Jul-15 8:00 PM
Subject: Re: [Geoserver-users] Broken links in thread
[Please keep discussions on-list]
Jair,
delivery of the web content is not configured in GeoServer; it is
configured on your web site. GeoServer will respond to requests from
the client browser generated using, for example, OpenLayers JavaScript.
GeoServer is the server, and OpenLayers JavaScript is the client.
On the server that hosts www.example.com, there should be a directory
that stores your web content. For example, it might be /var/www or
/home/username/public_html. It likely has an index.html in it. If
you add an HTML file demo.html in this directory you should be able
to access it as http://www.example.com/demo.html .
Place the content of this example in your demo.html and change the
ImageWMS url and params to reference your WMS:
http://openlayers.org/en/v3.7.0/examples/wms-image.html
Here is the catch: GeoServer must be somewhere external users can access
it.
For example: http://services.example.com/geoserver and perhaps your
WMS service endpoint is http://services.example.com/geoserver/wms ,
but it is also fine for them to be on the same server. You might have
something like this in OpenLayers:
url: 'http://services.example.com/geoserver/wms’,
params: {'LAYERS': 'ns:layername'},
where ns:layername is your layer name.
When a web user loads http://www.example.com/demo.html their browser
loads the JavaScript which then makes requests to
http://services.example.com/geoserver/wms to get the rendered images
on demand, with new requests as they pan and zoom.
There are many excellent examples for OpenLayers:
Kind regards,
Ben.
On 23/07/15 14:37, Jair Santos wrote:
Yes, I realized that Ben. I created the data store, opened the layer
and saw the data.
I don't know how to setup in the Geoserver the web site that will
display the data.
Let's say that I have the site www.example.com, where do I enter
this information in Geoserver and how to set it up?
Thank you.
JJ.
Sent: 22-Jul-15 7:19 PM
To: Jair Santos; GeoServer Mailing List List
Jair,
you already have PostGIS installed so all you need to do is connect
GeoServer. See this quick-start guide:
http://docs.geoserver.org/latest/en/user/gettingstarted/postgis-quic
ks
tart/i
ndex.html#create-a-data-store
Each table or view in PostGIS can be published as a layer. You can
then render these using WMS (see the OpenLayers preview). Now create
a web page that uses OpenLayers configured to display your new WMS
service:
(although it looks like the demo WMS is down; try using your new
WMS!)
More PostGIS detail:
http://docs.geoserver.org/latest/en/user/data/database/postgis.html
Kind regards,
Ben.
On 23/07/15 12:42, Jair Santos wrote:
Thank you Ben.
Actually I've just installed Geoserver and I have some PostGis data
that I want to make available in the web. Reading the manuals I
found out that I need to use WMS, and I am trying to understand how
it works. I saw the description of several commands or functions
such as GetCapabilities , GetFeatureInfo, etc..
I thought that to make the map available in the web I needed only
to adjust settings in Geoserver pretty much like a normal web
server. Am I
wrong?
If you can point me to information about how to do that I will
appreciate very much.
Best regards.
JJ
Sent: 22-Jul-15 5:31 PM
Jair,
those links are from 2006! The nearest I can think of is the
Styling section in the User Manual:
http://docs.geoserver.org/latest/en/user/styling/index.html
The User Manual also has a Tutorials section, but you might start
at the top level as a quick way of finding all the getting started,
reference, and tutorial documentation:
Are you looking for something in particular?
Kind regards,
Ben.
On 23/07/15 11:32, Jair Santos wrote:
Hello Everyone
In this thread there are two links that I am interested in:
http://sourceforge.net/p/geoserver/mailman/message/11250960/
Both links were served by CODEHAUS which services are terminated.
Does anybody know where the documents can pointed out by these
links
are?
Thanks
JJ
Geoserver-users mailing list
Ben Caradoc-Davies <ben@anonymised.com> Director Transient Software
Limited <http://transient.nz/&gt; New Zealand
-------- _______________________________________________
Director
Transient Software Limited <http://transient.nz/&gt; New Zealand
