[Geoserver-users] WMS-C missing anti-aliasing?
why in QGIS (http://geoserver:8080/geoserver/gwc/service/wms?TILED=true) everything looks pixelated, but not in OpenLayers preview?
Is there a trick?
yobiSource
QGIS can resize or transform images. So maybe your QGIS view has another scale and/or projection than your service?
On 12/10/2012 11:15 PM, yobiSource wrote:
Is there a trick?
LogMeIn Rescue: Anywhere, Anytime Remote support for IT. Free Trial
Remotely access PCs and mobile devices and provide instant support
Improve your efficiency, and focus on delivering more value-add services
Discover what IT Professionals Know. Rescue delivers
[http://p.sf.net/sfu/logmein_12329d2d](http://p.sf.net/sfu/logmein_12329d2d)
Geoserver-users mailing list
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
Terglobo
Ampèrestraat 110
5223 CT 's-Hertogenbosch
06-25314983
On Mon, Dec 10, 2012 at 11:15 PM, yobiSource <yobisource@anonymised.com> wrote:
Is there a trick?
There is no magic setting.
It probably means QGIS is rescaling the tiles client side to make them fit the local map scale, probably with nearest neighbor interpolation.
In order to show you the data without pixxellation QGIS should limit you to only use the scale denominators natively supported
by the tiled server, which it’s probably not doing.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
In QGIS 1.8, you find in the “View” menu the “Tile Scale Slider”. This adds a scale indicator to the QGIS interface. Upon opening a tiled service in QGIS, the steps at which the tiles are available are indicated in the Tile Scale Slider. Thus, you can view the tiles at the intended scale without any interpolation of pixel values.
HTH
Edward
Date: Tue, 11 Dec 2012 09:45:31 +0100
To: yobisource@anonymised.com
CC: geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] WMS-C missing anti-aliasing?
Is there a trick?
Ing. Andrea Aime
@geowolf
Technical Lead
------------------------------------------------------------------------------ LogMeIn Rescue: Anywhere, Anytime Remote support for IT. Free Trial Remotely access PCs and mobile devices and provide instant support Improve your efficiency, and focus on delivering more value-add services Discover what IT Professionals Know. Rescue delivers http://p.sf.net/sfu/logmein_12329d2d
_______________________________________________ Geoserver-users mailing list Geoserver-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-users
That makes sense, thanks for the info and the "Tile Scale Slider".
yobiSource
