[Geoserver-users] WMS Calls with SRS 900913 not working in new version (from 1.6.3?)
I am just getting crazy with not being able to get the new geoserver (I
tried both 1.6.3 and 1.7.0 alpha) working with 900913 projection, I would
appreciate any support on this!
I need to overlay google maps with colored country shapes. Now russia is not
shown, because obviously the background map (google maps) uses the dateline
as map border and geoserver 1.6.0 (which I use in production) does not
suppport 'wrapDateLine': true which should (whenever it is implemented)
solve that issue. I upgraded to both 1.6.3 and then to 1.7.0 (assuming that
this was a bug rather than a feature, but I am not so firm on that) and then
I discovered the following: my own layer did not show up anymore, at all.
I had a look at geoserver's logs and tried to play around with queries like:
/geoserver/wms?LAYERS=namespace%3Awhatever&TRANSPARENT=TRUE&SRS=EPSG%3A900913&FORMAT=image%2Fpng&TILED=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&BBOX=-20037508.34,-7.081154550627918e-10,0,20037508.340000033&WIDTH=256&HEIGHT=256
- they worked for the 1.6.0 version but NOT for the newer ones. I havent
found anything on a change of that functionality, so I am puzzled. Does
anyone know why that could happen? Can it be that this is a bug?
Big thanks in advance!
Reinhard
Additional info: I work with Openlayers 2.6, the data is stored in Postgis,
View this message in context: http://www.nabble.com/WMS-Calls-with-SRS-900913-not-working-in-new-version-(from-1.6.3-)-tp17084331p17084331.html
I have tried to replicate this behavior with the latest 1.6 and cant seem too... My guess is it might be something else that is causing the map to show up blank, other than the projection. Is there chance you provide us with a dump of some of your data?
ReinhardF wrote:
Reinhard
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Log Output from geoserver Version 1.6.2 where the map is shown:
2008-05-30 10:02:40,626 INFO [geoserver.filters] - Not compressing output
for mimetype: image/png
2008-05-30 10:02:40,626 INFO [geoserver.filters] - 86.59.104.243 "GET
/geoserver/wms?LAYERS=ecoresearch%3Aus2008&TRANSPARENT=TRUE&SRS=EPSG%3A900913&FORMAT=image%2Fpng&TILED=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&BBOX=0,-7.081154550627918e-10,20037508.34,20037508.340000033&WIDTH=256&HEIGHT=256"
took 493ms
Log Output from new Version 17.0 alpha where only a blank png is returned:
2008-05-30 08:04:42,814 INFO [org.geoserver.filters] - 127.0.0.1 "GET
/geoserver/wms?LAYERS=ecoresearch%3Aus&TRANSPARENT=TRUE&SRS=EPSG%3A900913&FORMAT=image%2Fpng&TILED=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&BBOX=0,-7.081154550627918e-10,20037508.34,20037508.340000033&WIDTH=256&HEIGHT=256"
"Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.9b5) Gecko/2008050509
Firefox/3.0b5" ""
2008-05-30 08:04:42,877 DEBUG [org.vfny.geoserver.global] - getting type
meins:geovote
2008-05-30 08:04:42,877 DEBUG [org.geoserver.ows] - Getting layers and
styles from LAYERS and STYLES
2008-05-30 08:04:42,877 DEBUG [org.geoserver.ows] - establishing
geovote_style style for meins:geovote
2008-05-30 08:04:42,879 DEBUG [org.vfny.geoserver.wms.responses] - setting
up map
2008-05-30 08:04:42,879 DEBUG [org.vfny.geoserver.responses.wms.map] -
setting up 256x256 image
2008-05-30 08:04:42,880 DEBUG [org.vfny.geoserver.responses.wms.map] -
setting to transparent
2008-05-30 08:04:42,881 WARN [org.geotools.referencing.operation.projectio]
- Possible use of "Mercator_1SP (Inverse transform)" projection outside its
valid area.
Longitude 180°42.2'E is out of range (±180°).
2008-05-30 08:04:43,106 DEBUG [org.vfny.geoserver.wms.responses] - asking
delegate for write to org.geoserver.ows.DispatcherOutputStream@anonymised.com
2008-05-30 08:04:43,106 DEBUG [org.vfny.geoserver.wms.responses.map.png] -
Writing png image ...
2008-05-30 08:04:43,116 DEBUG [org.vfny.geoserver.wms.responses.map.png] -
Writing png image ... done!
2008-05-30 08:04:43,117 INFO [org.geoserver.filters] - 127.0.0.1 "GET
took 303ms
Currently I don't need the solution, I am doing a quick workaround for the
problem which made me want to upgrade, but I still think, this is an issue.
Reinhard
Justin Deoliveira-4 wrote:
ReinhardF wrote:
not
dateline
that
then
like:
Reinhard
Postgis,
Justin Deoliveira
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference
Don't miss this year's exciting event. There's still time to save $100.
Use priority code J8TL2D2.
http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone
Geoserver-users mailing list
View this message in context: http://www.nabble.com/WMS-Calls-with-SRS-900913-not-working-in-new-version-(from-1.6.3-)-tp17084331p17553693.html
ReinhardF ha scritto:
took 493ms
1.7.0 alpha is very old, many bugs have been fixed since then. We're
already at beta level now, but we haven't released an official beta
so far. If you want to try out a more recent 1.7.0 series please
download a nightly build from here:
http://gridlock.openplans.org/geoserver/trunk/
And see if the error is still there.
I believe you're seeing the same problem Stefan and "springrider" are
seeing in the two threads titled "900913 and postgis layer without a native srs" and "Problem of projection for data stored in Oracle Locator".
Unfortunately I'm too busy to have a look at it right now, but can
any of you open a bug report for this?
Bug report is available at:
http://jira.codehaus.org/browse/GEOS-1961
not
dateline
that
then
like:
Locator".
Defy all challenges. Microsoft(R) Visual Studio 2008.
View this message in context: http://www.nabble.com/WMS-Calls-with-SRS-900913-not-working-in-new-version-(from-1.6.3-)-tp17084331p17555335.html
I'm having a problem with 900913 projection too. It does display, it works
pretty well, except that it is showing my data in the sea of ochotsk,
whereas it should be in the Netherlands. Is this a known problem?
It might also have to do with postgis import (the data is on the correct
location in arcGIS), but since I see there are problems with the 900913
projection it seemed logical to ask here first.
(Geoserver does recognize the 900913 projection when importing data. )
Any suggestions/help would be great!
Jonas
ReinhardF wrote:
not shown, because obviously the background map (google maps) uses the
dateline as map border and geoserver 1.6.0 (which I use in production)
does not suppport 'wrapDateLine': true which should (whenever it is
implemented) solve that issue. I upgraded to both 1.6.3 and then to 1.7.0
(assuming that this was a bug rather than a feature, but I am not so firm
on that) and then I discovered the following: my own layer did not show up
anymore, at all.
like:
Reinhard
Postgis,
View this message in context: http://www.nabble.com/WMS-Calls-with-SRS-900913-not-working-in-new-version-(from-1.6.3-)-tp17084331p19624068.html
Hi Jonas... have you already found a solution? If not, can you provide some
additional infos, such as where you got the data from, how you converted it,
version, etc?
Reinhard
Jonasvsl wrote:
Jonas
ReinhardF wrote:
up
anymore, at all.
like:
Reinhard
Postgis,
This SF.Net email is sponsored by the Moblin Your Move Developer's
challenge
Build the coolest Linux based applications with Moblin SDK & win great
prizes
Grand prize is a trip for two to an Open Source event anywhere in the
world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
View this message in context: http://www.nabble.com/WMS-Calls-with-SRS-900913-not-working-in-new-version-(from-1.6.3-)-tp17084331p20034630.html
