[Geoserver-users] WMS Coverage Styling
Begin forwarded message:
Date: June 7, 2007 1:43:02 AM MDT
Subject: WMS Coverage Styling
Hey All,
I have a couple of quick questions regarding styling a WMS Coverage layer. See <http://www.davisworld.org/zoom0-tiles3.png&gt; to help visualize what I am talking about.
The green squares are the footprints of the actual images on disk.
The red squares are the 256x256 pixel WMS requests (technically tiles coming from OpenLayers/TileCache, but I've verified that the output looks the same doing straight WMS requests to Geoserver directly)
Where are th "footprints" coming from?
And the coverages, are these mosaics? How did you built it?
I had both reports of gdaltindex generating broken index shapefiles,
and about the mosaic plugin not returning images at full resolution.
So, mosaic + gdaltindex issues could explain all you've seeing, yet
we have no cure for it so far.
You can check if the mosaic index file is broken easily, just point
geoserver at it and have it render it (if that's not what you're
already doing, that is...)
Question #1: Background color for absent pixels
Sometimes the background is black, sometimes it is white, and sometimes it is Red Xs. Is this significant? Do the colors mean different things are happening under the covers? I'd like it to be all black.
Big red X is returned when the mosaic plugin has issues afaik, but I
may be mistaken. White, I don't know why you're getting it.
actually this case seems to be a little strange … is possible to have some more details? Are you using OpenLayers and GeoServer to represent this image?
I think that black tiles could be images of the mosaic which are not well-formed.
As far as I can recall now, you can substitute red Xs with some custom image just replacing a unav.png image in the imagemosaic jar, and they come out usually when the requested tile is unavailable … but your case presents some strange behaviours IMHO, I should inspect a little deeper this problem.
Hey All,
layer. See < http://www.davisworld.org/zoom0-tiles3.png> to help
coming from OpenLayers/TileCache, but I’ve verified that the output
Where are th “footprints” coming from?
So, mosaic + gdaltindex issues could explain all you’ve seeing, yet
geoserver at it and have it render it (if that’s not what you’re
already doing, that is…)
different things are happening under the covers? I’d like it to be all
black.
may be mistaken. White, I don’t know why you’re getting it.
Eng. Alessio Fabiani
Vice-President /CTO GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 349 8227000
Thanks for the hint about unav.png.
I'm working on some other aspects of the project right now, but when/if I get chance to circle back, I might ping you.
s
Scott Davis
scott@anonymised.com
On Jun 8, 2007, at 8:43 AM, Alessio Fabiani wrote:
actually this case seems to be a little strange ... is possible to have some more details? Are you using OpenLayers and GeoServer to represent this image?
As far as I can recall now, you can substitute red Xs with some custom image just replacing a unav.png image in the imagemosaic jar, and they come out usually when the requested tile is unavailable ... but your case presents some strange behaviours IMHO, I should inspect a little deeper this problem.
On 6/7/07, Andrea Aime <aaime@anonymised.com> wrote: > Begin forwarded message:
>> From: Scott Davis <scott@anonymised.com>
>> Hey All,
>> layer. See < http://www.davisworld.org/zoom0-tiles3.png&gt; to help
>> black.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
