[Geoserver-users] WMS customization
I am very new to Geoserver and doing some tests with it. So far I
successfully achieved to load datas from :
-shapefiles (test:rva_troncons layer)
-postgis (test:rva_adresses layer)
-wms (openstreet map; osm_wms layer).
Here is the request.
localhost:8080/geoserver/rennes/wms?service=WMS&version=1.1.0&request=GetMap&layers=rennes:osm_wms,test:rva_troncons,test:rva_adresses&styles=&bbox=-2.130017195736699,47.76871944249505,-1.364852388513381,48.40717721351375&width=512&height=427&srs=EPSG:4326&format=application/openlayers&
Now I would like to customize the javascript generated by geoserver. For
instance, I would like the osm_wms always be loaded without having to
express it in the previous requests.
Does anyone have hints how this should be done ?
Thank you for your help.
François
View this message in context: http://osgeo-org.1560.x6.nabble.com/WMS-customization-tp5176011.html
Dear Francois,
the format=application/openlayers output format for WMS is there for
testing purposes, GeoServer is a back-end software is not a mapping
front-end.
You'd need to look into OpenLayers, Leaflet or other more complete solutions.
Simone Giannecchini
Please, notice that GeoSolutions will be closed for seasonal holidays
from December the 24th to January the 6th
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Tue, Dec 2, 2014 at 3:24 PM, franchouze <franchouze_llf@anonymised.com> wrote:
François
Download BIRT iHub F-Type - The Free Enterprise-Grade BIRT Server
from Actuate! Instantly Supercharge Your Business Reports and Dashboards
with Interactivity, Sharing, Native Excel Exports, App Integration & more
Get technology previously reserved for billion-dollar corporations, FREE
http://pubads.g.doubleclick.net/gampad/clk?id=157005751&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Thank you for your answer, I will look at those.
Best regards,
François
View this message in context: http://osgeo-org.1560.x6.nabble.com/WMS-customization-tp5176011p5176139.html
