[Geoserver-users] WMS decorations - image
HI List,
I’m dabbling with WMS decorations - http://docs.geoserver.org/stable/en/user/advanced/wmsdecoration.html
Nice and simple, but alas am having problems loading an image.
I have:
But no image is rendering, and there are no events in the log telling me why (I’ve tried a lot of different logging levels, including GEOSERVER_DEV and VERBOSE - nothing in any that I can see).
I’ve put the file in /layouts/, and I’ve put it in the root geoserver_data_dir, but in neither case does it show.
Documentation says:
provides the URL or file path to the image to draw (relative to the GeoServer data directory)
It does work if I use a full URL (i.e. http://example.com/wcc_logo_trans.png )
Anyone have any suggestions for why the local copy isn’t working?
Jonathan
This transmission is intended for the named addressee(s) only and may contain confidential, sensitive or personal information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
