Ciao Alan,
notice that GeoServer is able to accept TIME as part of a WMS 1.1.1 request
but this has never been hooked up for vector data (like postgis
tables) but only for custom raster formats.
Notice also that as aaime correctly pointed out this is not too hard to support.
Ciao,
Simone.
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Fri, Apr 10, 2009 at 6:19 PM, Andrea Aime <aaime@anonymised.com> wrote:
Alan Beccati ha scritto:
Hello,
Does anybody knows if WMS Dimensions, expecially time dimension (mapped
to postgresql date column), is supported by the current release of
GeoServer?
If so, where can I find some documentation on how to configure the feature?
Nope, GeoServer does not support time/elevation. Support on vector data
should not be that hard to add, but requires some knowledge of
the GeoServer internals.
If you really need it right now you can try to patch GeoServer yourself
(in this case join us on the devel list) or have some commercial support
providers do it for you:
http://geoserver.org/display/GEOS/Commercial+Support
As an alternative, you can use our custom CQL_FILTER parameter that
allows one to build basically every kind of filter on data you're
interested into. As an example, try to add &CQL_FILTER=PERSONS>10000000
on the topp:states map preview and you'll see how it works.
More examples of the CQL syntax here:
http://docs.codehaus.org/display/GEOTDOC/01+CQL+Examples
Andrea Aime
OpenGeo - http://opengeo.org
This SF.net email is sponsored by:
High Quality Requirements in a Collaborative Environment.
Download a free trial of Rational Requirements Composer Now!
http://p.sf.net/sfu/www-ibm-com
Geoserver-users mailing list
