I am still working on geting multiple layers to identify on OpenLayers 4.
Currently I am getting an Error WMS does not permit cross origin framing (firefox) and chrome says Resource interpreted as Document but transferred with MIME type application/xml. I strongly believe this has to do with the way I have sent the request to Geoserver. I have been reading on WMS getfeature info but I cannot put out the correct code or how to set GetFeature info paramaters in the code. I know where to find information such as services,bbox on individual WMS urls. Perharps someone can point me to a code to set WMS get feature info parameters request.
Here is my current code
map.on(‘click’, function (evt) {
var url = GetFeatureInfoUrl = ‘http://localhost:8080/geoserver/County/wms’
‘evt.coordinate’, ‘viewResolution’, ‘viewProjection’, ‘EPSG:3857’,
{‘INFO_FORMAT’: ‘text/html’,
‘QUERY_LAYERS’: ‘County:Boundary,County:Regions,County:Constituencies,County:Towns’};
if (url) {
document.getElementById(‘info’).innerHTML =
content.innerHTML = ‘’;
Filling in some of those headers is a matter of configuring the application server. Are you using tomcat application server, or the default ‘jerry’ application server we provide with the standalone geoserver application.
if (url) {
Thank you all for your assistance.
Best regards
Amelia
engaging tech sites, Slashdot.org! http://sdm.link/slashdot_______________________________________________
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
Have you tried hand-crafting a WFS GetFeatureInfo request and sending that directly from your browser manually? Using the browser’s dev tools you’ll then see if you get the headers/etc you need back. That will indicate if the issue is with the GeoServer/Tomcat side, or the OpenLayers end making a bad request.
Jonathan
On 2018-07-04 08:01, Nauwanga Nauwanga wrote:
Dear Jody
I am using Tomcat,I tried uncomenting the CORS Filter in the xml using the // but still did not take away the error?
if (url) {
Best regards
Amelia
Check out the vibrant tech community on one of the world's most
engaging tech sites, Slashdot.org! [http://sdm.link/slashdot](http://sdm.link/slashdot)
- Earning your support instead of buying it, but Ian Turton: [http://www.ianturton.com/talks/foss4g.html#/](http://www.ianturton.com/talks/foss4g.html#/)
- The GeoServer user list posting guidelines: [http://geoserver.org/comm/userlist-guidelines.html](http://geoserver.org/comm/userlist-guidelines.html)
If you want to request a feature or an improvement, also see this: [https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer](https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer)
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@anonymised.comsourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
