[Geoserver-users] WMS file into Geoserver
Hello all,
I have a WMS file downloaded from DataBC and I would like to view it and make it available in Geoserver WMS. It is an xml file. They recommend to connect the WMS directly to the geospatial software so whenever they update the data in their warehouse it will automatically updated.
Does anybody knows how I do that in geoserver?
TIA
JJ.
Jair,
direct connection to DataBC services is performed not in GeoServer but in your OpenLayers interface. The client accesses these services directly through OpenLayers, which allows these layers to be combined with your custom GeoServer layers in their web browser.
Look in the WMS column on the DataBC Services page:
http://www.data.gov.bc.ca/dbc/geographic/connect/index.page
For each link remove everything after the "?", leaving you with the service URL. Use this in OpenLayers just as you did for GeoServer.
XML files obtained from a WMS are often KML (for Google Earth or similar). As KML is already a portrayal format not a data format, it is unsuitable for loading into a database or delivery by GeoServer. I recommend direct connection via DataBC WMS services, as described above. Less work, and clients get the most up-to-date map.
Kind regards,
Ben
On 29/07/15 06:45, Jair Santos wrote:
Hello all,
TIA
JJ.
Geoserver-users mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
Thanks Ben,
I initially tried to load the data using Geoserver's "WMS - Cascades a
remote Web Map Service". I've got a bunch of layers that when published were
empty (I think).
Cheers.
JJ.
-----Original Message-----
From: Ben Caradoc-Davies [mailto:ben@anonymised.com]
Sent: 28-Jul-15 1:20 PM
To: Jair Santos <jsantos5954@anonymised.com>; GeoServer Mailing List List
<geoserver-users@lists.sourceforge.net>
Subject: Re: [Geoserver-users] WMS file into Geoserver
Jair,
Kind regards,
Ben
Hello all,
updated.
TIA
JJ.
Director
Transient Software Limited <http://transient.nz/&gt; New Zealand
