Simon,
actually the geotiff plugin doesn’t provide that capability.
Anyway, you can leverage on the ImageMosaic plugin which provides better color transparency management.
By this way you can setup a simple mosaic containing only your geotiff and handle background as you need.
More info about this are available here:
http://docs.codehaus.org/display/GEOSDOC/Using+the+ImageMosaic+plugin
Daniele
On Wed, Mar 18, 2009 at 9:12 AM, Simon Janssens <simon.janssens@anonymised.com> wrote:
Daniele,
It’s exactly what I want to do…
I’ve tried with the SLD but the GeoTIFF uses a palette.
I think that changing the raster SLD is not the best solution…
wkr,
Simon
-----Original Message-----
From: dany.geotools@anonymised.com [mailto:dany.geotools@anonymised.com]On Behalf Of Daniele Romagnoli
Sent: dinsdag 17 maart 2009 17:06
To: Simon Janssens
Subject: Re: [Geoserver-users] WMS && GeoTIFF - Don’t show a specific color
Simon,
can you give us more details on your intended usage?
Do you want to let become transparent, the background color saved in your GeoTiff?
Daniele
On Tue, Mar 17, 2009 at 3:02 PM, Simon Janssens <simon.janssens@anonymised.com> wrote:
I create GeoTIFF with picture files and set a “background color”. I would like to show WMS with created GeoTIFF but without the background color…
How do I specify to GeoServer to provide WMS with the GeoTIFF without the background color??
Simon
Apps built with the Adobe(R) Flex(R) framework and Flex Builder™ are
powering Web 2.0 with engaging, cross-platform capabilities. Quickly and
easily build your RIAs with Flex Builder, the Eclipse™based development
software that enables intelligent coding and step-through debugging.
Download the free 60 day trial. http://p.sf.net/sfu/www-adobe-com
Geoserver-users mailing list
Eng. Daniele Romagnoli
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 328 0559267
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi again,
the right link is this one:
http://geoserver.org/display/GEOSDOC/Using+the+ImageMosaic+plugin
Daniele
On Wed, Mar 18, 2009 at 10:16 AM, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Simon,
Daniele
Daniele,
wkr,
Simon
To: Simon Janssens
Simon,
Daniele
Simon
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
