[Geoserver-users] WMS GetCapabilities Failing Geoserver 1.7.2
I have just noticed that my GetCapabilites requests are failing with the following error.
Translator error
Translator error
null
Details:
org.vfny.geoserver.wms.WmsException: Translator error
at org.vfny.geoserver.wms.responses.WMSCapabilitiesResponse.execute(WMSCapabilitiesResponse.java:143)
at org.geoserver.ows.adapters.ResponseAdapter.getMimeType(ResponseAdapter.java:48)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:698)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:215)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:354)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
Caused by: javax.xml.transform.TransformerException: Translator error
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
at org.vfny.geoserver.wms.responses.WMSCapabilitiesResponse.execute(WMSCapabilitiesResponse.java:141)
… 53 more
Caused by: java.lang.NullPointerException
at org.vfny.geoserver.wms.responses.helpers.WMSCapsTransformer$CapabilitiesTranslator.handleFeatureType(WMSCapsTransformer.java:730)
at org.vfny.geoserver.wms.responses.helpers.WMSCapsTransformer$CapabilitiesTranslator.handleFeaturesTree(WMSCapsTransformer.java:648)
at org.vfny.geoserver.wms.responses.helpers.WMSCapsTransformer$CapabilitiesTranslator.handleLayers(WMSCapsTransformer.java:514)
at org.vfny.geoserver.wms.responses.helpers.WMSCapsTransformer$CapabilitiesTranslator.handleCapability(WMSCapsTransformer.java:331)
at org.vfny.geoserver.wms.responses.helpers.WMSCapsTransformer$CapabilitiesTranslator.encode(WMSCapsTransformer.java:215)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
… 55 more
GetMap and GetFeatureInfo are both working fine.
Is there anything i may have missed config wise in order for this to be happening?
Brad
Bradley Mclain
Systems Administrator Trainee
De Bortoli Wines Pty limited
De Bortoli Rd, BILBUL NSW 2680
e: bradley_mclain@anonymised.com
Hi Bradley,
This can be a result of a getFeature request where propertyNames are set to be returned.
If in those propertyNames the geometry field is not mentioned this error occurs.
See the thread called “a simple zoom to feature …”. Its fixed in the nighty builds so I expect it to be released with geoserver 1.7.3
Cheers Kris
From: Bradley McLain [mailto:bradley_mclain@…2009…]
Sent: Tuesday, February 17, 2009 4:16 AM
To: Geoserver-Users
Subject: [Geoserver-users] WMS GetCapabilities Failing Geoserver 1.7.2
Translator error
Translator error
null
Details:
… 53 more
… 55 more
Brad
Bradley Mclain
e: bradley_mclain@…2009…
    at
You have one layer whose default style does not exist.
Before 1.7.2 that situation made GeoServer silently
produce an invalid capabilities document (as in, invalid
xml, un-balanced tags), now you get a hard exception instead.
But humm... there is nothing helping you locate
which layer has a non existing default style.
I'll schedule a jira to try and provide a better message.
http://jira.codehaus.org/browse/GEOS-2629
In the meantime, the layer that makes your caps generation
fail should respond with a service exception also to
the GetMap made by the GeoServer preview (since that one does
not specify a named style, and thus makes the code lookup
the default style). This might help you narrow down the
misconfigured layer.
Andrea Aime
OpenGeo - http://opengeo.org
Thanks I found the offending layer and changed the default style to polygon. I guess it’s a good lesson in using the built in styles as defaults and then specifying custom when requesting.
I am now having another problem, I can’t create any new feature types
Getting the following error, I checked to make sure that geoserver/tomcat is running as the tomcat user but that failed to fix it ( I following the centos 5.1 install guide)
class javax.servlet.ServletException: javax.servlet.jsp.JspException: ServletException in ‘/WEB-INF/pages/data/featureTypes/New.jsp’: /opt/apache-tomcat-6.0.18/work/Catalina/localhost/geoserver/org/apache/jsp/WEB_002dINF/pages/data/featureTypes/New_jsp.java (Permission denied)
This happens both on the local machine and over the network.
Any ideas on this one?
Brad
2009/2/17 Andrea Aime <aaime@anonymised.com>
at
But humm… there is nothing helping you locate
I’ll schedule a jira to try and provide a better message.
Andrea Aime
Bradley Mclain
Thanks I found the offending layer and changed the default style to polygon. I guess it's a good lesson in using the built in styles as defaults and then specifying custom when requesting.
I am now having another problem, I can't create any new feature types
class javax.servlet.ServletException: javax.servlet.jsp.JspException: ServletException in '/WEB-INF/pages/data/featureTypes/New.jsp': /opt/apache-tomcat-6.0.18/work/Catalina/localhost/geoserver/org/apache/jsp/WEB_002dINF/pages/data/featureTypes/New_jsp.java (Permission denied)
It may be that you run tomcat once as root, and that file
got generated with those permissions. Now Tomcat is trying
to recompile the same page, and it's failing to delete
the old version.
Anyways, when you upgrade GeoServer it's a good idea
to wipe out the contents of the Tomcat work directory,
as converted jsp pages are cached there and you might
end up dealing with stale versions.
Andrea Aime
