[Geoserver-users] WMS GetCapabilities Request throws a Translator Error
Hi
I wrote a Servlet to create new FeatureTypes on GeoServer. This
servlet runs (separetely) on GeoServer itself. This works great. But
after I added new FeatureTypes and send a WMS GetCapabilities Request
to GeoServer I get a Translator Error. Does anyone know why?
I think the (at the end of this mail) added excecption must be
something todo with following code.
<code>
FeatureTypeInfoDTO featureType = new FeatureTypeInfoDTO();
String tmp = request.getParameter("keywords").split(",");
if (tmp != null && tmp.length > 0)
  for (int i=0; i<tmp.length; i++)
    featureType.addKeyword(tmp[i]);
//... save to XML and reload GeoServer catalog
</code>
Sorry if this post receive you perhaps two times. Nabble.com had a
problem and I got a timeout so I don't know if this message is really
posted.
Thank you!
Regards, Thomas
I get following Exception:
Now I forgot the exception:
I put the exception in a Textfile.
View this message in context: Re: WMS GetCapabilities Request throws a Translator Error
Hi Thomas,
Can you be more specific on how you are saving to XML and reloading the
catalog. I think what is happening is you just have a featureType with
no keywords, and null is creeping in along the lines. Depending on if
you are using the exact same code to reload the catalog that GeoServer
does on startup, this case should be handled as XMlConfigReader returns
an empty list when it finds no keywords.
Regardless of that, I think the capabilities transformer should just do
a null check since its good practice anyways.
-Justin
Thomas Zuberbuehler wrote:
Hi
<code>
</code>
posted.
Thank you!
Regards, Thomas
opinions on IT & business topics through brief surveys-and earn cash
Geoserver-users mailing list
!DSPAM:1004,45ed7416288722223018498!
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Hi Justin
I get the DataDTO object (dataDTO) with the XMLConfigReader, call
following code and write the changes with help of XMLConfigWriter to
filesystem.
<code>
Map fts = dataDTO.getFeaturesTypes();
fts.put((dataStoreID + ":::" + featureTypeName), featureType);
dataDTO.setFeaturesTypes(fts);
</code>
I reload the GeoServer catalog with a connection to
".../admin/loadFromXML.do" as like described at GeoServer homepage. I
make this unattractive workaround because I use a simple Servlet
without Spring and Struts.
The servlet works aside described bug. The feature types will added
without any exception and errors. And they can displayed with
MapBuilder as well. And when I edit the added feature types (only
press submit) the WMS GetCapabilities request works too.
Regards, Thomas
2007/3/6, Justin Deoliveira <jdeolive@anonymised.com>:
Hi Thomas,
-Justin
> Hi
> <code>
> </code>
> posted.
> Thank you!
> Regards, Thomas
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
Justin Deoliveira
Thomas Zuberbuehler
http://www.zubi.li
Hmm, since our xml config is by no means simple trying to debug this one
is far from worth it. I am going to commit a fix to just check for null
in the capabilities transformer. Especially since the wcs and wfs
capabilities already do it.
Are you working from svn Thomas?
-Justin
Hi Justin
filesystem.
<code>
</code>
Regards, Thomas
Hi Thomas,
-Justin
Hi
<code>
</code>
posted.
Thank you!
Regards, Thomas
Justin Deoliveira
Justin Deoliveira
Yes, sometimes. In this case I get GeoServer 1.5 from svn and import
the geoserver.war to Eclipse. With the build from website I do not
have problems. With the your modified version from svn I get following
exception:
SCHWERWIEGEND: Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error
creating bean with name 'validation' defined in URL
[jar:file:/Users/Zubi/Documents/Eisenhut%20Informatik%20AG/AdminTool/Eclipse%20Workspace/.metadata/.plugins/org.eclipse.wst.server.core/tmp0/webapps/geoserver5/WEB-INF/lib/validation-1.5.0-RC1.jar!/applicationContext.xml]:
Can't resolve reference to bean 'config' while setting property
'constructor argument'; nested exception is
creating bean with name 'config' defined in URL
[jar:file:/Users/Zubi/Documents/Eisenhut%20Informatik%20AG/AdminTool/Eclipse%20Workspace/.metadata/.plugins/org.eclipse.wst.server.core/tmp0/webapps/geoserver5/WEB-INF/lib/main-1.5.0-RC1.jar!/applicationContext.xml]:
Initialization of bean failed; nested exception is
org.springframework.beans.factory.BeanInitializationException: Error
creating xml config reader; nested exception is
org.vfny.geoserver.global.ConfigurationException:
java.lang.NullPointerException
org.vfny.geoserver.global.ConfigurationException: java.lang.NullPointerException
  at org.vfny.geoserver.global.xml.XMLConfigReader.loadCatalog(XMLConfigReader.java:363)
  at org.vfny.geoserver.global.xml.XMLConfigReader.load(XMLConfigReader.java:195)
  at org.vfny.geoserver.global.xml.XMLConfigReader.<init>(XMLConfigReader.java:153)
  at org.vfny.geoserver.global.Config.setApplicationContext(Config.java:51)
  at org.springframework.context.support.ApplicationContextAwareProcessor.postProcessBeforeInitialization(ApplicationContextAwareProcessor.java:84)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:248)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:362)
  at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:226)
  at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:147)
  at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:176)
  at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:105)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.resolveConstructorArguments(AbstractAutowireCapableBeanFactory.java:713)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:611)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:329)
  at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:275)
  at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:318)
  at org.springframework.web.context.support.AbstractRefreshableWebApplicationContext.refresh(AbstractRefreshableWebApplicationContext.java:134)
  at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:230)
  at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:156)
  at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:48)
  at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3827)
  at org.apache.catalina.core.StandardContext.start(StandardContext.java:4343)
  at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1083)
  at org.apache.catalina.core.StandardHost.start(StandardHost.java:789)
  at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:478)
  at org.apache.catalina.core.StandardService.start(StandardService.java:480)
  at org.apache.catalina.core.StandardServer.start(StandardServer.java:2313)
  at org.apache.catalina.startup.Catalina.start(Catalina.java:556)
  at java.lang.reflect.Method.invoke(Method.java:324)
  at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:287)
  at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:425)
Caused by: java.lang.NullPointerException
  at org.vfny.geoserver.global.xml.XMLConfigReader.loadFeatureTypes(XMLConfigReader.java:1271)
  at org.vfny.geoserver.global.xml.XMLConfigReader.loadCatalog(XMLConfigReader.java:360)
  ... 36 more
-Justin
> Hi Justin
> filesystem.
> <code>
> </code>
> Regards, Thomas
>> Hi Thomas,
>> -Justin
>>> Hi
>>> <code>
>>> </code>
>>> posted.
>>> Thank you!
>>> Regards, Thomas
>>> _______________________________________________
>> Justin Deoliveira
Justin Deoliveira
Thomas Zuberbuehler
http://www.zubi.li
I forgot to write. This exception on startup I get also before your
changes. I get this exception only with a build from svn.
2007/3/6, Thomas Zuberbuehler <tzuberbuehler@anonymised.com>:
exception:
        ... 36 more
> -Justin
> > Hi Justin
> > filesystem.
> > <code>
> > </code>
> > Regards, Thomas
> >> Hi Thomas,
> >> -Justin
> >>> Hi
> >>> <code>
> >>> </code>
> >>> posted.
> >>> Thank you!
> >>> Regards, Thomas
> >> Justin Deoliveira
> Justin Deoliveira
Thomas Zuberbuehler
http://www.zubi.li
Thomas Zuberbuehler
http://www.zubi.li
Well from what I can tell this is happening because the featureTypes
directory does not exist. On server starup you should get a message
saying what the GEOSERVER_DATA_DIRECTORY is set to. Is there a
"featureTypes" directory under the directory it reports?
-Justin
exception:
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        ... 36 more
one
> -Justin
> > Hi Justin
> > filesystem.
> > <code>
> > </code>
> > Regards, Thomas
> >> Hi Thomas,
reloading the
with
on if
returns
just do
> >> -Justin
> >>> Hi
But
Request
> >>> <code>
> >>> </code>
really
> >>> posted.
> >>> Thank you!
> >>> Regards, Thomas
to share your
cash
> >> Justin Deoliveira
> Justin Deoliveira
Thomas Zuberbuehler
http://www.zubi.li
Justin Deoliveira
Hum.... if the user points to an invalid data directory, what shall we do?
For sure, we should complain loudly if the directory does not exist.
What about checking its structural integrity as well? And maybe creating
the necessary folders?
The GEOSERVER_DATA_DIRECTORY is set to
/Users/Zubi/Documents/Eisenhut Informatik AG/AdminTool/Eclipse
workspace/.metadata/.plugins/org.eclipse.wst.server.core/tmp0/webapps/geoserver5/data
Unfortunately there is not a "featureTypes" directory. Why not? (With
official releases from website there are an automatically created
"featureTypes" directory.) I will try to add this directory.
-Thomas
-Justin
exception:
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        ... 36 more
one
null
> -Justin
> > Hi Justin
> > filesystem.
> > <code>
> > </code>
I
> > Regards, Thomas
> >> Hi Thomas,
reloading the
with
on if
returns
just do
> >> -Justin
> >>> Hi
But
Request
> >>> <code>
> >>> </code>
really
> >>> posted.
> >>> Thank you!
> >>> Regards, Thomas
to share your
cash
> >> Justin Deoliveira
> Justin Deoliveira
Thomas Zuberbuehler
http://www.zubi.li
Justin Deoliveira
your
View this message in context: http://www.nabble.com/WMS-GetCapabilities-Request-throws-a-Translator-Error-tf3355483.html#a9335650
Well my opinion has always been to never die in cases like these. As you
suggest spit out a warning saying the directory does not exist, and
create it. Ideally we should still be able to start up with none of data
dir directories being around.
-Justin
!DSPAM:1004,45ed985f322992081064789!
Justin Deoliveira
When I added this directory manually then I get new exception:
  at org.vfny.geoserver.global.GeoValidator.loadPlugins(GeoValidator.java:92)
  at org.vfny.geoserver.global.GeoValidator.<init>(GeoValidator.java:60)
  at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
  at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
  at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
  at java.lang.reflect.Constructor.newInstance(Constructor.java:274)
  at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:100)
  at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:75)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:669)
-Thomas
-Justin
>> exception:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 36 more
>> one
>> > -Justin
>> > > Hi Justin
>> > > filesystem.
>> > > <code>
>> > > </code>
>> > > Regards, Thomas
>> > >> Hi Thomas,
>> reloading the
>> with
>> on if
>> GeoServer
>> returns
>> just do
>> > >> -Justin
>> > >>> Hi
>> But
>> Request
>> > >>> <code>
>> > >>> </code>
>> really
>> > >>> posted.
>> > >>> Thank you!
>> > >>> Regards, Thomas
>> to share your
>> cash
>> > >> Justin Deoliveira
>> > Justin Deoliveira
>> Thomas Zuberbuehler
>> http://www.zubi.li
Justin Deoliveira
Thomas Zuberbuehler
http://www.zubi.li
Same problem but with the "plugIns" directory. Your data directory
structure should look as described here:
http://docs.codehaus.org/display/GEOSDOC/GeoServer+Data+Directory
With an actual example available here:
http://svn.codehaus.org/geoserver/branches/1.5.x/configuration/release/
-Justin
    at
Method)
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
-Thomas
-Justin
>> exception:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 36 more
>> one
for null
>> > -Justin
>> > > Hi Justin
XMLConfigWriter to
>> > > filesystem.
>> > > <code>
>> > > </code>
homepage. I
added
>> > > Regards, Thomas
>> > >> Hi Thomas,
>> reloading the
>> with
>> on if
>> GeoServer
>> returns
>> just do
>> > >> -Justin
>> > >>> Hi
>> But
>> Request
>> > >>> <code>
>> > >>> </code>
had a
>> really
>> > >>> posted.
>> > >>> Thank you!
>> > >>> Regards, Thomas
>> to share your
>> cash
>> > >> Justin Deoliveira
>> > Justin Deoliveira
>> Thomas Zuberbuehler
>> http://www.zubi.li
Justin Deoliveira
Justin Deoliveira
Agreed. Can you open an issue for this? Handling it for 1.5.0 is probably a bit late, given the number of issues we already have to deal with, but would be nice to deal with it for 1.6.0
Can do. It is also a step in the right direction to being able to set up
mock testing.
http://jira.codehaus.org/browse/GEOS-956
-Justin
!DSPAM:1004,45ed9b61327301527717022!
Justin Deoliveira
Justin, Thank you for your great help!!
You rescued my day. It works!
Regards over the ocean,
Thomas
-Justin
> at
> Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> -Thomas
>> -Justin
>> >> exception:
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> ... 36 more
>> >> one
>> for null
>> >> > -Justin
>> >> > > Hi Justin
>> XMLConfigWriter to
>> >> > > filesystem.
>> >> > > <code>
>> >> > > </code>
>> homepage. I
>> added
>> >> > > Regards, Thomas
>> >> > >> Hi Thomas,
>> >> reloading the
>> >> with
>> >> on if
>> >> GeoServer
>> >> returns
>> >> just do
>> >> > >> -Justin
>> >> > >>> Hi
>> >> But
>> >> Request
>> >> > >>> <code>
>> >> > >>> </code>
>> had a
>> >> really
>> >> > >>> posted.
>> >> > >>> Thank you!
>> >> > >>> Regards, Thomas
>> >> to share your
>> >> cash
>> >> > >> Justin Deoliveira
>> >> > Justin Deoliveira
>> >> Thomas Zuberbuehler
>> >> http://www.zubi.li
>> Justin Deoliveira
Justin Deoliveira
Thomas Zuberbuehler
http://www.zubi.li
