[Geoserver-users] WMS GetCapabilities w/ latest 1.4 release
hello there,
when trying to get the WMS capabilities (with the GetCapabilities request)
w/ the latest 1.4.0 release, i get the following exception:
org.geotools.ows.ServiceException: Error while parsing XML.
  at org.geotools.data.wms.response.WMSGetCapabilitiesResponse.<init>(WMSGetCapabilitiesResponse.java:52)
  at org.geotools.data.wms.WMS1_0_0$GetCapsRequest.createResponse(WMS1_0_0.java:227)
  at org.geotools.data.ows.AbstractOpenWebService.internalIssueRequest(AbstractOpenWebService.java:371)
  at org.geotools.data.wms.WebMapServer.issueRequest(WebMapServer.java:99)
  at org.geotools.data.ows.AbstractOpenWebService.negotiateVersion(AbstractOpenWebService.java:172)
  at org.geotools.data.ows.AbstractOpenWebService.<init>(AbstractOpenWebService.java:77)
  at org.geotools.data.wms.WebMapServer.<init>(WebMapServer.java:83)
  at au.com.forge.mapIntelligence.geoserver.TestOfWMSGetCapabilities.testGeoToolsAPI(TestOfWMSGetCapabilities.java:173)
  at junit.framework.TestCase.runTest(TestCase.java:154)
  at junit.framework.TestCase.runBare(TestCase.java:127)
  at junit.framework.TestCase.run(TestCase.java:118)
  at junit.framework.TestSuite.runTest(TestSuite.java:208)
  at junit.framework.TestSuite.run(TestSuite.java:203)
  at org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestReference.run(JUnit3TestReference.java:128)
  at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
  at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:460)
  at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:673)
  at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:386)
  at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:196)
Caused by: org.gjt.xpp.XmlPullParserException: <![DOCTYPE declarations not supported at line 2 and column 114 seen ...080/geoserver/schemas/wms/1.1.1/WMS_MS_Capabilities.dtd"... (parser state UNKNONW_EVENT (-1))
  at org.gjt.xpp.sax2.Driver.parse(Driver.java:304)
  at javax.xml.parsers.SAXParser.parse(SAXParser.java:375)
  at javax.xml.parsers.SAXParser.parse(SAXParser.java:176)
  at org.geotools.xml.DocumentFactory.getInstance(DocumentFactory.java:139)
  at org.geotools.data.wms.response.WMSGetCapabilitiesResponse.<init>(WMSGetCapabilitiesResponse.java:50)
  ... 25 more
this didn't use to happen w/ the previous (RC) release. am i missing
something, or is it a known regression?
cheers;
rsn
hello all,
org.geotools.ows.ServiceException: Error while parsing XML...
this i believe is a GeoTools (client-side) related issue and not a GeoServer
one. i'm rephrasing the question and posting it to the geotools mailing
list.
apologies for the noise + cheers;
rsn
