[Geoserver-users] WMS GetFeatureInfo JSON format disabled in 2.1.4?
We’re running GS 2.1.4, and trying to get JSON emitted as the output format for WMS GetFeatureInfo.
The URL we’re using is generated by OpenLayers and looks like:
http://tom1/geoserver/wms?LAYERS=CIS_LKI_SEGMENT_PUBLISHED_V&QUERY_LAYERS=CIS_LKI_SEGMENT_PUBLISHED_V&STYLES=&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&BBOX=437798.846609%2C303877.971488%2C1954309.487576%2C1820388.612455&FEATURE_COUNT=3&HEIGHT=620&WIDTH=620&FORMAT=image%2Fpng&INFO_FORMAT=application%2Fjson&SRS=EPSG%3A3005&X=250&Y=117&PROPERTYNAME=LKI_SEGMENT_EXT_ID%2COPPOSITE_LKI_SEGMENT_EXT_ID
Note the INFO_FORMAT=application%2Fjson, which appears correct.
However, this generates the error:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
Invalid format 'application/json', supported formats are [text/plain, application/vnd.ogc.gml, text/html]
We enabled ENABLE_JSONP in case there was some interaction there (although there shouldn’t be), but it didn’t fix the problem.
Did 2.1.4 support JSON output for WMS GetFeatureInfo? And if so, any reason it would be disabled?
On Thu, Jan 31, 2013 at 7:41 PM, Martin Davis <mtnclimb@anonymised.com> wrote:
Hum… I don’t think it did. Going by memory, support for JSON was added only
recently in the 2.2.x series (as in, a few days ago, with the backport of
Carlo’s work, right after the 2.2.4 release).
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks… good to know I can stop looking. 8^)
Does that resolve http://jira.codehaus.org/browse/GEOS-1294 ?
On Thu, Jan 31, 2013 at 11:31 AM, Andrea Aime <andrea.aime@anonymised.com…> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Jan 31, 2013 at 8:49 PM, Martin Davis <mtnclimb@anonymised.com> wrote:
Ah yes, it does, thanks for pointing that out
Ing. Andrea Aime
@geowolf
Technical Lead
