Thank you for your quick response!
I get the feeling that the ticket GEOS-5377 is not the same problem as I’m having. I believe that my problem arises from these lines of code in GetFeatureInfo.identifyVectorLayer:
FeatureCollection<? extends FeatureType, ? extends Feature> match;
match = featureSource.getFeatures(q);
// if we could not include the rules filter into the query, post process in
// memory
if (!Filter.INCLUDE.equals(postFilter)) {
match = new FilteringFeatureCollection(match, postFilter);
The query, q, in the call to the getFeatures method is defined as:
Query q = new Query(typeName, null, getFInfoFilter, maxFeatures,
propertyNames, null);
and I suspect that the maxFeatures variable that is used in creating the query q is used to limit the number of features returned by the getFeatures method.
And if the rules of the SLD are applied afterwards as a postFilter, the number of features actually returned by the GetFeatureInfo request may be lower than maxFeatures.
I will attempt to recreate the problem in a test environment and if I succeed I will post the results here.
/ Johan
On Tue, Nov 26, 2013 at 2:48 PM, Johan Behrenfeldt <johan.behrenfeldt@anonymised.com> wrote:
My mistake! Of course, I should’ve included that piece of information.
The version in which I encountered my problem is 2.1.3 (subversion: revision 16668).
If I look at the GEOS-5377 ticket, I can see that was fixed in version 2.2.2 and upgrading to version 2.2.2 or later may solve my problem. However, this is an issue that I’ve encountered in a production environment where I cannot upgrade GeoServer without going through a long process and I would want to be rather certain that the upgrade will fix my problem before going through that process.
Is there any way I can see what code changes were made to resolve the ticket? Seeing what code was changed to fix the ticket would give me a chance to make a qualified guess whether my problem has been solved or not.
Aaah… See, that makes it very easy to answer:
https://github.com/geoserver/geoserver/commit/9f159ded4f0c8da8c3742bdbdbb2463b9cf42a10
and as a patch:
https://github.com/geoserver/geoserver/commit/9f159ded4f0c8da8c3742bdbdbb2463b9cf42a10.patch
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
