[Geoserver-users] WMS GetFeatureInfo & Time Series Data
Sounds interesting. There might be more use for such queries from multidimensional coverages.
Have you been thinking what could be the best way to enhance WCS with such new query type "GetCoverageInfo" in some close-to-standard way? Could it be a special outputformat as you did plus some vendor option "CoverageInfoParameters"?
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: Jeroen Dries [mailto:jeroen.dries@anonymised.com]
Lähetetty: 12. marraskuuta 2014 9:57
Vastaanottaja: geoserver-users@lists.sourceforge.net
Aihe: Re: [Geoserver-users] WMS GetFeatureInfo & Time Series Data
Hi Mike,
I had exactly the same problem. I solved it using the multidimensional
outputformat support in the geoserver WCS implementation. I wrote a custom
multidimensional outputformat encoder, which encodes to json. Then I send
WCS GetCoverage requests to geoserver, using something like 'custom/json' as
the outputformat.
My outputformat code then receives a 'GranuleStack', which I encode to json.
If you're interested in this approach, I can lookup some code pointers and
possible workarounds that were needed to get this to work.
best regards,
Jeroen
On Monday 10 November 2014 11:34:24 Mike Grogan wrote:
> With a time-enabled image mosaic as the data store, is there an easy
> way to get multiple return values for time series raster data via
> GetFeatureInfo (or anything else available on GeoServer)?
> For instance, in one request I would like to get all values for a grid
> cell for all times available in the mosaic. So, say I have hourly
> rasters covering a 24 hour period, I would like to return the 24
> hourly values at a particular lat/lon in a single request.
> Thanks,
> Mike Grogan
Comprehensive Server Monitoring with Site24x7.
Monitor 10 servers for $9/Month.
Get alerted through email, SMS, voice calls or mobile push notifications.
Take corrective actions from your mobile device.
http://pubads.g.doubleclick.net/gampad/clk?id=154624111&iu=/4140/ostg.clktr
k
Geoserver-users mailing list
Hello,
for my use case, the standard WCS 2.0 options were sufficient, only the outputformat is not described by a standard, but that’s not so relevant as it’s plain text json.
If you are thinking about more complex queries, than you can have a look at http://www.opengeospatial.org/standards/wcps . (Do note that writing a full implementation would be very complex, and also the queries which you have to send as a client can become quite large.)
What type of vendor options were you thinking about?
best regards,
Jeroen
On Wednesday 12 November 2014 08:39:31 Rahkonen Jukka wrote:
new query type “GetCoverageInfo” in some close-to-standard way? Could it be
“CoverageInfoParameters”?
-Jukka Rahkonen-
Hi Mike,
WCS GetCoverage requests to geoserver, using something like ‘custom/json’
as the outputformat.
My outputformat code then receives a ‘GranuleStack’, which I encode to
json.
If you’re interested in this approach, I can lookup some code pointers and
best regards,
Jeroen
Mike Grogan
---- Comprehensive Server Monitoring with Site24x7.
r
k
– Comprehensive Server Monitoring with Site24x7.
http://pubads.g.doubleclick.net/gampad/clk?id=154624111&iu=/4140/ostg.clktrk
