[Geoserver-users] WMS GetFeatureInfo with CQL Filter don't support Chinese?
Thak you !
I am usding GetFeatureInfo to get Feature Info.
Read a Textfield 's value ,then use it as filter.
I want to know how to write the params and which params are necessary.
The exception is Could not parse CQL filter list. Lexical error at line 1, column 11. Encountered: “\u2018” (8216), after : “”. Parsing : NAME LIKE ‘?E2??. Current Token : “NAME” .
Can I use Chinese in CQL_FILTER ?
How should I set these params and CQL_FILTER?
var params = {
REQUEST: “GetFeatureInfo”,
EXCEPTIONS: “application/vnd.ogc.se_xml”,
BBOX: map.getExtent().toBBOX(),
INFO_FORMAT: ‘application/vnd.ogc.gml’,
QUERY_LAYERS: map.layers[0].params.LAYERS,
FEATURE_COUNT: 50,
Layers: ‘CHN’,
Styles: ‘’,
Srs: ‘EPSG:4326’,
format: format};
Request=OpenLayers.loadURL(“http://159.226.13.203:8080/geoserver/wms?CQL_FILTER=NAME LIKE ‘%上海%’”, params, this, highlight, setHTMLx);
function highlight(response){
document.getElementById(‘nodelist’).innerHTML = response.responseText;
alert(“sss”);
var doc = response.responseXML;
if(!doc || !doc.documentElement) {
doc = response.responseText;
features = parseformat.read(doc);
highlightLayer.addFeatures(features);
On Thu, Apr 8, 2010 at 7:13 AM, <ahwangyuwei@anonymised.com> wrote:
Thak you !
column 11. Encountered: "\u2018" (8216), after : "". Parsing : NAME LIKE
‘?E2??. Current Token : "NAME" .
var params = {
REQUEST: "GetFeatureInfo",
EXCEPTIONS: "application/vnd.ogc.se_xml",
INFO_FORMAT: 'application/vnd.ogc.gml',
FEATURE_COUNT: 50,
Layers: 'CHN',
Styles: '',
Srs: 'EPSG:4326',
format: format};
Request=OpenLayers.loadURL("http://159.226.13.203:8080/geoserver/wms?CQL_FILTER=NAME
LIKE ‘%上海%’", params, this, highlight, setHTMLx);
I think that your Chinese characters will need to be escaped in the
URL. There is a possibility that OpenLayers can do that if you add the
CQL_FILTER as a parameter in the code rather than directly to the URL.
As to whether GeoServer can handle them in a CQL filter, I think it
should but others on the GeoServer list will know better.
Ian
Ian Turton
