On Wed, Sep 24, 2014 at 11:02 AM, Mauro Bartolomeoli <
maurobartolomeoli@anonymised.com> wrote:
Which version of GeoServer are you using?
In recent versions the WMS GetFeatureInfo behaviour changed to only
respond on clicks done on pixels that are rendered on the map, so what you
describe can probably happen if you are using a linear style (no fill) to
draw your polygons.
Which was a bug, and was recently solved, I believe 2.5.2 has the fix for
this (so it will return the polygon even if it's not filled)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
