This was discussed already in June but did it lead to fix?
http://comments.gmane.org/gmane.comp.gis.geoserver.user/42254
-Jukka Rahkonen-
Mauro Bartolomeoli wrote:
Which version of GeoServer are you using?
In recent versions the WMS GetFeatureInfo behaviour changed to only respond on clicks done on pixels that are rendered on the map, so what you describe can probably happen if you are using a linear style (no fill) to draw your polygons.
Mauro
2014-09-23 12:07 GMT+02:00 astrony <astrony@…84…>:
Dear All,
May i have some question about WMS GetFeatureInfo on the polygon geometry. I
have no idea that when i tried to click on my polygon (exactly polygon in
database) for get information through Layer Preview in Geoserver, i cant get
it when click inside but it is work when i click on its bound. I am so
confusing. Did i do something incorrect in my data or Geoserver?
Thanks in advance to enlighten in this issue
Br,
astrony
View this message in context: http://osgeo-org.1560.x6.nabble.com/WMS-GetFeatureInfo-with-Polygon-tp5163455.html
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer
Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports
Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper
Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer
http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk
Geoserver-users mailing list
