[Geoserver-users] WMS GetFeatureInfo with "vendorParams" does not work like before after upgrade to 2.5.x
I made some tests with Geoserver versions 2.5.2 and 2.6 and for me the propertyName parameter does work for several query layers if I use the documented syntax http://docs.geoserver.org/stable/en/user/services/wms/vendor.html
"For multiple layers the syntax is:
propertyName=(nameLayer11,...,nameLayer1N)...(name1LayerN,...,nameNLayerN)"
Thus, give a separate propertyName list for each QUERY_LAYER. However, I noticed that Andrea already did some fix. I hope he will think again if the current behaviour has been implemented for reason and if the fix was fixing something that was not broken.
My comment on issue https://jira.codehaus.org/browse/GEOS-6604 includes test URLs which use our standard demo layers.
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: sys49152 [mailto:mr_bungle@anonymised.com]
Lähetetty: 11. elokuuta 2014 0:43
Vastaanottaja: geoserver-users@lists.sourceforge.net
Aihe: [Geoserver-users] WMS GetFeatureInfo with "vendorParams" does not
Last week I've upgraded to GeoServer 2.5.2 from 2.3.4 and now the same
GetFeatureInfo request in my web site returns different results.
I am using "vendorParams" to filter layers and their attributes because I dont
want to show all fields of a table in a popup when they made a query.
Code:
With GeoServer 2.3.4 if I run a WMS getFeatureInfo request using code above it
works like it should - it shows only desired attributes which are mentioned in
"vendorParams" and only from 2 layers i have stated in "layers".
But after upgrade to 2.5.2 it looks like that you cannot put attributes from more
than 1 layer because it returns
*"Internal error occurred PropertyDescriptor is null - did you request a property
that does not exist?"*
<http://osgeo-
org.1560.x6.nabble.com/file/n5155715/pitanje_za_geoserver_i_openlayers.jpg
If I leave only one layer in "layers" and its attributes in "vendorParams"
it works, but if you put more than one then throws an error.
Is this a bug or ...??
Thanks.
View this message in context: http://osgeo-org.1560.x6.nabble.com/WMS-
GetFeatureInfo-with-vendorParams-does-not-work-like-before-after-upgrade-
to-2-5-x-tp5155715.html
Geoserver-users mailing list
On Mon, Aug 11, 2014 at 12:47 PM, Rahkonen Jukka (Tike) <
jukka.rahkonen@anonymised.com> wrote:
documented syntax
I made a fix for propertyName being ignored, did not check the multiple
layer case, and won't be able to
this week, I'm leaving for vacation in the afternoon
If you find another issue, could you open a different ticket?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks for your suggestions on JIRA.
So, I tried corrected code below
  var info = new OpenLayers.Control.WMSGetFeatureInfo(
    url: "http://192.168.0.38/geoserver/jkp_naissus/wms&quot;,
    title: 'Identifikuj',
    layers: [vodovod, vodomeri], // fekalna, atmosferska, cesme
    vendorParams: {propertyName:['(SIFRA,NAZIV,ULICA,KUCNI_BROJ)
ULICA,MATERIJAL,DN_MM,IZVOR_INFORMACIJE)']},
and it works, BUT only If both layers are ON.
<http://osgeo-org.1560.x6.nabble.com/file/n5155914/12-8-2014_10-34-13.jpg&gt;
When one of those two layers are not visible (and my users quite often don't
use both layers on screen), then I got
*Mismatch between the property name set count 2 and the query layers count 1
<http://osgeo-org.1560.x6.nabble.com/file/n5155914/12-8-2014_10-34-44.jpg&gt;
I understand what this means but I now dont know how to create behaviour
like before - and that was to return only attributes which Ive put into
'propertyName' of choosen layers if they are found within a click.
Its obviously something changed in GeoServer and now I dont know how to do
the right thing.
Please could you instruct me more in detail how to do it, I am not an expert
Thanks for your efforts !
p.s
I have to say that documented syntax was the same last year for GeoServer
2.3.4 and my old code work without a problem. I had a problem with figuring
out how to do it proper syntax for more than one layer so I asked question
here a year ago
http://osgeo-org.1560.x6.nabble.com/WMS-vendor-quot-propertyName-quot-parameter-syntax-td5044926.html
<http://osgeo-org.1560.x6.nabble.com/WMS-vendor-quot-propertyName-quot-parameter-syntax-td5044926.html&gt;
View this message in context: http://osgeo-org.1560.x6.nabble.com/WMS-GetFeatureInfo-with-vendorParams-does-not-work-like-before-after-upgrade-to-2-5-x-tp5155715p5155914.html
