[Geoserver-users] WMS GetFeatureInfo
Sorry There are someting wrong with previous attached file so I send again.
To: worr <n_worr@anonymised.com>
Subject: Re: Re: [Geoserver-users] WMS GetFeatureInfo
Date: Tue, 11 Jul 2006 10:44:21 +0200
Thank you for your help. But unfortunately I didn`t get your attached file.
Could you send me the attachment again, please?
Best Regards
Nils
-------- Original-Nachricht --------
Datum: Mon, 10 Jul 2006 10:36:47 -0700 (PDT)
Von: worr <n_worr@anonymised.com>
An: geoserver-users@lists.sourceforge.net
Betreff: Re: [Geoserver-users] WMS GetFeatureInfo
> It was an error on the class SQLEncoderOracle.class in lib
> gt2-oracle-spatial.jar
> I already debug and It worked.You can use my attached file.
> View this message in context:
> http://www.nabble.com/WMS-GetFeatureInfo-tf1907679.html#a5255773
> Sent from the GeoServer - User forum at Nabble.com.
> Using Tomcat but need to do more? Need to support web services, security?
> Get stuff done quickly with pre-integrated technology to make your job
> easier
> Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
> http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
> Geoserver-users mailing list
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
"Feel free" – 10 GB Mailbox, 100 FreeSMS/Monat ...
Jetzt GMX TopMail testen: http://www.gmx.net/de/go/topmail
_________________________________________________________________
Express yourself instantly with MSN Messenger! Download today - it's FREE! http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
SQLEncoderOracle.java (23.2 KB)
I have problems to compile the SQLEncoderOracle.java file.
Could you please compile the file for me? That would be very nice:-)
Thanks Nils
Datum: Tue, 11 Jul 2006 09:34:22 +0000
Von: Worawit worr <n_worr@anonymised.com>
An: nkrueger@anonymised.com, geoserver-users@lists.sourceforge.net
Betreff: Re: Re: [Geoserver-users] WMS GetFeatureInfo
again.
>From: "Nils Krüger" <nkrueger@anonymised.com>
>Hi,
file.
>Best Regards
>Nils
>security?
> > easier
>Geronimo
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
Could you possibly send a patch? I'm having trouble figuring out exactly what has changed, as the code is a bit mangled. See: http://docs.codehaus.org/display/GEOSDOC/Creating+a+Patch
And if you submit it as a bug in jira and attach the patch there I can build a jar to be used by others.
best regards,
Chris
Best Regards
Nils
> easier
!DSPAM:1003,44b370ec180167731818748!
* Geotools2 - OpenSource mapping toolkit
* http://geotools.org
* (C) 2002, Geotools Project Managment Committee (PMC)
* This library is free software; you can redistribute it and/or
* modify it under the terms of the GNU Lesser General Public
* License as published by the Free Software Foundation;
* version 2.1 of the License.
* This library is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
* Lesser General Public License for more details.
package org.geotools.filter;
import java.io.IOException;
import java.util.Arrays;
import java.util.HashMap;
import java.util.Map;
import java.util.Set;
import java.util.logging.Logger;
import org.geotools.data.oracle.sdo.SDO;
import com.vividsolutions.jts.geom.Coordinate;
import com.vividsolutions.jts.geom.CoordinateSequence;
import com.vividsolutions.jts.geom.CoordinateSequenceFactory;
import com.vividsolutions.jts.geom.Geometry;
import com.vividsolutions.jts.geom.LineString;
import com.vividsolutions.jts.geom.Point;
import com.vividsolutions.jts.geom.Polygon;
* Encodes Geometry filters into valid oracle SDO statements.
* <p>
* At this stage it only supports the GEOMETRY_BBOX types.
* </p>
* <p>
* Encoded filters get written to the protected Writer called <code>out</code>
* </p>
* @author $Author: worr $
* @version $Id: SQLEncoderOracle.java,v 1.1 2006/07/03 04:48:51 worr Exp $
public class SQLEncoderOracle extends SQLEncoder {
   /** The capabilities of the encoder */
   private static FilterCapabilities capabilities = null;
   /** Logger - for logging */
   private static final Logger LOGGER = Logger.getLogger(
           "org.geotools.filter.SQLEncoderOracle");
   /** Contains filter type to SDO_RELATE mask type mappings */
   private static final Map SDO_RELATE_MASK_MAP = new HashMap();
   /** The standard SQL multicharacter wild card. */
   private static final String SQL_WILD_MULTI = "%";
   /** The standard SQL single character wild card. */
   private static final String SQL_WILD_SINGLE = "_";
   /** Default tolerance for spatial queries. */
   private static final String TOLERANCE = "0.001";
   static {
       SDO_RELATE_MASK_MAP.put(new Short(AbstractFilter.GEOMETRY_CONTAINS),
           "contains");
       SDO_RELATE_MASK_MAP.put(new Short(AbstractFilter.GEOMETRY_CROSSES),
           "overlapbydisjoint");
       SDO_RELATE_MASK_MAP.put(new Short(AbstractFilter.GEOMETRY_EQUALS),
           "equal");
       SDO_RELATE_MASK_MAP.put(new Short(AbstractFilter.GEOMETRY_OVERLAPS),
           "overlapbyintersect");
       SDO_RELATE_MASK_MAP.put(new Short(AbstractFilter.GEOMETRY_TOUCHES),
           "touch");
       SDO_RELATE_MASK_MAP.put(new Short(AbstractFilter.GEOMETRY_WITHIN),
           "inside");
       SDO_RELATE_MASK_MAP.put(new Short(AbstractFilter.GEOMETRY_DISJOINT),
           "disjoint");
       //Ok, back to using these, as the not disjoint turned out to be a big
       //performance hit. I would really like to see some solid testing on
       //these though, as with a trivial case it really did not seem to work
       //right, not disjoint was giving different answers than anyinteract.
       SDO_RELATE_MASK_MAP.put(new Short(AbstractFilter.GEOMETRY_BBOX),
           "anyinteract");
       SDO_RELATE_MASK_MAP.put(new Short(AbstractFilter.GEOMETRY_INTERSECTS),
           "anyinteract");
   /** The escaped version of the multiple wildcard for the REGEXP pattern. */
   //private String escapedWildcardMulti = "\W.\\*"; // "\\*"
   /** The escaped version of the single wildcard for the REGEXP pattern. */
   //private String escapedWildcardSingle = "\\.\\?";
    * The Spatial Reference System IDs Keyed by ColumnName, value is Integer
    * SRID number
   private Map srids;
   private String fidColumn;
   private String currentGeomColumnName = null;
   boolean inGeomFilter = false;
   public SQLEncoderOracle(String fidColumn, int defaultSRID) {
       this(new HashMap());
       this.fidColumn = fidColumn;
       srids.put(null, new Integer(defaultSRID));
       setSqlNameEscape("\"");
   public SQLEncoderOracle(int defaultSRID) {
       this(null, new HashMap());
    * Creates a new SQLEncoderOracle with a specified SRID.
    * @param srids DOCUMENT ME!
    * @param srids The Spatial Reference ID to use when generating SDO SQL
    * statements.
   public SQLEncoderOracle(String fidColumn, Map srids) {
       this.srids = srids;
       Set geomCols = srids.keySet();
       if (geomCols.size() > 0) {
           currentGeomColumnName = (String) geomCols.iterator().next();
       LOGGER.fine("SQLEncoderOracle: Geometric Column is: "
           + currentGeomColumnName);
    * statements.
   public SQLEncoderOracle(Map srids) {
       this(null, srids);
    * Sets the capabilities of this filter.
    * @return FilterCapabilities for this Filter
   protected FilterCapabilities createFilterCapabilities() {
       FilterCapabilities capabilities = super.createFilterCapabilities();
       capabilities.addType(AbstractFilter.GEOMETRY_BBOX);
       capabilities.addType(AbstractFilter.GEOMETRY_CONTAINS);
       capabilities.addType(AbstractFilter.GEOMETRY_CROSSES);
       capabilities.addType(AbstractFilter.GEOMETRY_DISJOINT);
       capabilities.addType(AbstractFilter.GEOMETRY_EQUALS);
       capabilities.addType(AbstractFilter.GEOMETRY_INTERSECTS);
       capabilities.addType(AbstractFilter.GEOMETRY_OVERLAPS);
       capabilities.addType(AbstractFilter.GEOMETRY_TOUCHES);
       capabilities.addType(AbstractFilter.GEOMETRY_WITHIN);
       capabilities.addType(AbstractFilter.GEOMETRY_DWITHIN);
       capabilities.addType(AbstractFilter.GEOMETRY_BEYOND);
       capabilities.addType(AbstractFilter.FID);
       capabilities.addType(AbstractFilter.LIKE);
       return capabilities;
    * Reverting back to just using anyinteract, as Thijs says this is a bad
    * performance hit
    * This is a special case for bbox and intersects filters, as the former
    * using of 'anyinteract' does not seem to be exactly a not disjoint,
    * which is what is needed according to ogc specs.
    * @param geomFilter DOCUMENT ME!
    * @throws IOException DOCUMENT ME!
   /* private void doNotDisjointFilter(GeometryFilter geomFilter)
       throws IOException {
       //String mask = (String) SDO_RELATE_MASK_MAP.get(new Short(
       // geomFilter.getFilterType()));
       Expression left = geomFilter.getLeftGeometry();
       Expression right = geomFilter.getRightGeometry();
       if (((left != null) || (currentGeomColumnName != null))
               && (right != null)) {
           inGeomFilter = true;
           out.write("NOT SDO_RELATE(");
           if (left != null) {
               left.accept(this);
           } else {
               out.write(currentGeomColumnName);
           out.write(",");
           right.accept(this);
           out.write(",'mask=disjoint querytype=WINDOW') = 'TRUE' ");
       } else {
           LOGGER.warning("Invalid filter. Cannot have a Geometry filter "
               + "with only one expression.");
   private void doSdoRelate(GeometryFilter geomFilter)
               /*&& (right != null)*/ && (mask != null)) {
           out.write("SDO_RELATE(");
           out.write("\"" + currentGeomColumnName + "\"");
           out.write(",");
           if (left != null) {
               left.accept(this);
           }/* else {
           //out.write(",");
           //right.accept(this);
           out.write(",'mask=" + mask + " querytype=WINDOW') = 'TRUE' ");
       } else {
    * Performs a geometry distance filter, must be either a dwithin or a
    * a beyond filter. Uses the SDO_WITHIN_DISTANCE function, dwithin matches
    * for true, beyond for false.
    * @param geomFilter the filter to use, must be a dwithin or beyond
   private void doSdoDistance(GeometryDistanceFilter geomFilter)
      // String mask = (String) SDO_RELATE_MASK_MAP.get(new Short(
       double distance = geomFilter.getDistance();
    //only dwithin and beyond, dwithin matches true for sdo_within_distance
       boolean isDWithin = geomFilter.getFilterType() ==
           AbstractFilter.GEOMETRY_DWITHIN;
    String boolValue = isDWithin ? "TRUE" : "FALSE";
       if ((left != null) && (right != null)) {
           out.write("SDO_WITHIN_DISTANCE(");
           left.accept(this);
           out.write(",");
           right.accept(this);
           out.write(",'distance=" + distance + "') = '" + boolValue + "' ");
       } else {
           LOGGER.warning("Invalid filter for DWithin. Cannot have a Geometry filter "
    * Converts JTS Geometry to a String version of a SDO Geometry. This
    * should move to a utility class, as we now have more than one class
    * using this (which is why it changed to public static). TODO: Multi
    * Geometries
    * @param geometry The JTS Geometry to convert.
    * @param srid DOCUMENT ME!
    * @return A String representation of the SDO Geometry.
   public static String toSDOGeom(Geometry geometry, int srid) {
       if (Point.class.isAssignableFrom(geometry.getClass())) {
           return toSDOGeom((Point) geometry, srid);
       } else if (LineString.class.isAssignableFrom(geometry.getClass())) {
           return toSDOGeom((LineString) geometry, srid);
       } else if (Polygon.class.isAssignableFrom(geometry.getClass())) {
           return toSDOGeom((Polygon) geometry, srid);
       } else {
           LOGGER.warning("Got a literal geometry that I can't handle: "
               + geometry.getClass().getName());
           return "";
    * Converts a LineString Geometry in an SDO SQL geometry construction
    * statement.
    * <p>
    * 2D geometries is assumed. If higher dimensional geometries are used the
    * query will be encoded as a 2D geometry.
    * </p>
    * @param line The line to encode.
    * @return An SDO SQL geometry object construction statement
   private static String toSDOGeom(LineString line, int srid) {
       if (SDO.D(line) > 2) {
           LOGGER.warning("" + SDO.D(line)
               + " dimensioned geometry provided."
               + " This encoder only supports 2D geometries. The query will be constructed as"
               + " a 2D query.");
       StringBuffer buffer = new StringBuffer("MDSYS.SDO_GEOMETRY(");
       buffer.append(SDO.D(line));
       buffer.append("002,");
       if (srid > 0) {
           LOGGER.fine("Using layer SRID: " + srid);
           buffer.append(srid);
       } else {
           LOGGER.fine("Using NULL SRID: ");
           buffer.append("NULL");
       buffer.append(",NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,2,1),");
       buffer.append("MDSYS.SDO_ORDINATE_ARRAY(");
       Coordinate coordinates = line.getCoordinates();
       for (int i = 0; i < coordinates.length; i++) {
           buffer.append(coordinates[i].x);
           buffer.append(",");
           buffer.append(coordinates[i].y);
           if (i != (coordinates.length - 1)) {
               buffer.append(",");
       buffer.append("))");
       return buffer.toString();
    * Converts a Point Geometry in an SDO SQL geometry construction statement.
    * <p>
    * </p>
    * @param point The point to encode.
   private static String toSDOGeom(Point point, int srid) {
       if (SDO.D(point) > 2) {
           LOGGER.warning("" + SDO.D(point)
               + " a 2D query.");
       buffer.append(SDO.D(point));
       buffer.append("001,");
       if (srid > 0) {
       } else {
       buffer.append(",MDSYS.SDO_POINT_TYPE(");
       buffer.append(point.getX());
       buffer.append(",");
       buffer.append(point.getY());
       buffer.append(",NULL),NULL,NULL)");
    * Converts a Polygon Geometry in an SDO SQL geometry construction
    * statement.
    * <p>
    * </p>
    * @param polygon The polygon to encode.
   private static String toSDOGeom(Polygon polygon, int srid) {
       StringBuffer buffer = new StringBuffer();
       if (SDO.D(polygon) > 2) {
           LOGGER.warning("" + SDO.D(polygon)
               + " a 2D query.");
       if (polygon.getExteriorRing() != null) {
           buffer.append("MDSYS.SDO_GEOMETRY(");
           buffer.append(SDO.D(polygon));
           buffer.append("003,");
           if (srid > 0) {
           } else {
           buffer.append(",NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,1),");
        CoordinateSequenceFactory fact = polygon.getFactory().getCoordinateSequenceFactory();
        CoordinateSequence exterior = polygon.getExteriorRing().getCoordinateSequence();
        CoordinateSequence coordSeq = SDO.counterClockWise(fact, exterior);
           for (int i = 0, size = coordSeq.size(); i < size; i++) {
        Coordinate cur = coordSeq.getCoordinate(i);
               buffer.append(cur.x);
               buffer.append(",");
               buffer.append(cur.y);
               if (i != (size - 1)) {
                   buffer.append(",");
        /* This could be expensive if coordSeq implementation is not an
           an array. Leaving in for now as I can't test, and this is
           more likely to work right.
           Coordinate coordinates = coordSeq.toCoordinateArray();
               buffer.append(",");
                   buffer.append(",");
       } else {
           LOGGER.warning("No Exterior ring on polygon. "
               + "This encode only supports Polygons with exterior rings.");
       if (polygon.getNumInteriorRing() > 0) {
           LOGGER.warning("Polygon contains Interior Rings. "
               + "These rings will not be included in the query.");
    * Handles Geometry Filter encoding. Currently only supports the encoding
    * of GEOMETRY_BBOX filters. If a GEOMETRY_BBOX filter is encounter it
    * will be converted into an SDO_RELATE() function. If another filter is
    * found, nothing will happen.
    * @param geomFilter The geometry filter to encode.
    * @see org.geotools.filter.FilterVisitor#visit(org.geotools.filter.GeometryFilter)
   public void visit(GeometryFilter geomFilter) {
       LOGGER.finer("Visiting a Geometry filter");
       try {
        short filterType = geomFilter.getFilterType();
        if ((filterType == AbstractFilter.GEOMETRY_DWITHIN)
        || (filterType == AbstractFilter.GEOMETRY_BEYOND)){
               //doSdoDistance((GeometryDistanceFilter)geomFilter);
        //} else if (filterType == AbstractFilter.GEOMETRY_INTERSECTS
        //|| filterType == AbstractFilter.GEOMETRY_BBOX) {
               //doNotDisjointFilter(geomFilter);
           } else
           if (SDO_RELATE_MASK_MAP.get(new Short(geomFilter.getFilterType())) != null) {
               doSdoRelate(geomFilter);
           } else {
               LOGGER.warning("Unknown filter type: "
                   + geomFilter.getFilterType());
       } catch (IOException e) {
           LOGGER.warning("IO Error exporting geometry filter");
    * Writes the SQL for the Like Filter. Assumes the current java
    * implemented wildcards for the Like Filter: . for multi and .? for
    * single. And replaces them with the SQL % and _, respectively. Currently
    * does nothing, and should not be called, not included in the
    * capabilities.
    * @param filter the Like Filter to be visited.
    * @task TODO: LikeFilter doesn't work right...revisit this when it does.
    * Need to think through the escape char, so it works right when
    * Java uses one, and escapes correctly with an '_'.
   public void visit(LikeFilter filter) {
       try {
           String pattern = filter.getPattern();
           String multi = "\\Q"+filter.getWildcardMulti()+"\\E";
           pattern = pattern.replaceAll( multi, SQL_WILD_MULTI);
           String single = "\\Q"+filter.getWildcardSingle()+"\\E";
           pattern = pattern.replaceAll( single, SQL_WILD_SINGLE);
           //pattern = pattern.replace('\\', ''); //get rid of java escapes.
           out.write("UPPER(");
           ((Expression) filter.getValue()).accept(this);
           out.write(") LIKE ");
           out.write("UPPER('" + pattern + "')");
           String esc = filter.getEscape();
           if (pattern.indexOf(esc) != -1) { //if it uses the escape char
               out.write(" ESCAPE " + "'" + esc + "'"); //this needs testing
           //TODO figure out when to add ESCAPE clause, probably just for the
           // '_' char.
       } catch (java.io.IOException ioe) {
           LOGGER.warning("Unable to export filter" + ioe);
    * Converts a literal expression into a valid SDO object. Only handles
    * Literal Geometries, all other literals are passed up to the parent.
    * @param literal The Literal expression to encode.
    * @see org.geotools.filter.FilterVisitor#visit(org.geotools.filter.LiteralExpression)
   public void visit(LiteralExpression literal) {
       if (literal.getType() == DefaultExpression.LITERAL_GEOMETRY) {
           Geometry geometry = (Geometry) literal.getLiteral();
           try {
               int srid = -1;
               Integer sridO = (Integer) srids.get(currentGeomColumnName);
               if (sridO == null) {
                   // try for default
                   sridO = (Integer) srids.get(null);
               if (sridO != null) {
                   srid = sridO.intValue();
               out.write(toSDOGeom(geometry, srid));
               LOGGER.warning("IO Error exporting Literal Geometry");
       } else {
           // can't do it, send it off to the parent
           super.visit(literal);
    * DOCUMENT ME!
    * @param filter
    * @see org.geotools.filter.SQLEncoder#visit(org.geotools.filter.FidFilter)
   public void visit(FidFilter filter) {
       if (fidColumn != null) {
           String fids = filter.getFids();
           LOGGER.finer("Exporting FID=" + Arrays.asList(fids));
           for (int i = 0; i < fids.length; i++) {
               try {
                   out.write(fidColumn);
                   out.write(" = '");
                   int pos;
                   if ((pos = fids[i].indexOf('.')) != -1) {
                       out.write(fids[i].substring(pos + 1));
                   } else {
                       out.write(fids[i]);
                   out.write("'");
                   if (i < (fids.length - 1)) {
                       out.write(" OR ");
                   LOGGER.warning("IO Error exporting FID Filter.");
       } else {
           super.visit(filter);
    * (non-Javadoc)
    * @see org.geotools.filter.SQLEncoder#visit(org.geotools.filter.AttributeExpression)
   public void visit(AttributeExpression ae) throws RuntimeException {
       super.visit(ae);
       if (inGeomFilter) {
           currentGeomColumnName = ae.getAttributePath();
Get stuff done quickly with pre-integrated technology to make your job easier
Chris Holmes
The Open Planning Project
http://topp.openplans.org
