Good Morning Stefano,
thank you for pointing that out, but that only is a typo in the email. I added the sld back in for the example. We use a code generator to create a few of our styles and it generated the sld prefix into the xml whether I wanted it to or not, so this has gotten to be a painful issue I’ll have to work around.
I’ll open the Jira later on, gotta get this functionality done first.
Michael
To: Michael Colin <Colin_Michael@…7234…>
Cc: Mauro Bartolomeoli <maurobartolomeoli@…84…>, GeoServer Mailing List List geoserver-users@lists.sourceforge.net
Date: 15/09/2015 05:47 PM
Subject: Re: [Geoserver-users] WMS GetLegendGraphic i18n
Hi Michael,
On Tue, Sep 15, 2015 at 3:52 AM, Michael Colin <Colin_Michael@…7234…> wrote:
Localized doesn’t seem to accept a namespace. In my example the following wouldn’t work whereas the 2nd snipped worked:
<?xml version="1.0" encoding="UTF-8"?><sld:StyledLayerDescriptor xmlns="[http://www.opengis.net/sld](https://urldefense.proofpoint.com/v2/url?u=http-3A__www.opengis.net_sld&d=BQMFaQ&c=p0oa49nxxGtbbM2qgM-GB4r4m9OlGg-sEp8sXylY2aQ&r=A3KdcnVyFqLMOOqCdo2429zd-IRYbqVdYcNdu2zOiik&m=3G3IhVc0OiXsvLHMjZaW2vyx3O4BjKjrgm7-0Sl5v-8&s=ncyEGol8WVISAXYSzEqWDYeExv0g3MEVMO-sAX5OWKs&e=)" xmlns:sld="[http://www.opengis.net/sld](https://urldefense.proofpoint.com/v2/url?u=http-3A__www.opengis.net_sld&d=BQMFaQ&c=p0oa49nxxGtbbM2qgM-GB4r4m9OlGg-sEp8sXylY2aQ&r=A3KdcnVyFqLMOOqCdo2429zd-IRYbqVdYcNdu2zOiik&m=3G3IhVc0OiXsvLHMjZaW2vyx3O4BjKjrgm7-0Sl5v-8&s=ncyEGol8WVISAXYSzEqWDYeExv0g3MEVMO-sAX5OWKs&e=)" ....
sld:TitleDesign
<sld:Localized lang=“es”>Diseño
<sld:Localized lang=“pt”>Design
<sld:Localized lang=“ru”>Точность сетки
</sld:Title>
The closing Localized tags in your snippet are wrong, they should be </sld:Localized> (qualified): perhaps this is why the example doesn’t work? Or maybe it’s just a typo in your e-mail…
Best regards,
Stefano Costa
Dott. Stefano Costa
Senior Software Engineer
Via Poggio alle Viti 1187
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
