On Sat, May 16, 2015 at 6:07 PM, Arthur F. Zanona <arthur@anonymised.com>
wrote:
Hello,
I have a problem with the heatmap. This layer is set in the projection
4326.
When viewing the layer with projection pseudo-mercator(3857) sometimes it
is not displayed.
Hum... you're the second to report an issue with rendering transformations
over raster data + reprojection
not producing outputs, I guess it's a bug.
We have a 2.7.1 release in just 2 days, I won't be able to make a fix by
then, but I hope to find time
to look into it for 2.6.4, due next month.
Could you open a bug report at https://osgeo-org.atlassian.net/projects/GEOS
with sample data, style,
and steps to reproduce? (so that we can replicate your problem on a
developer's machine?)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
