[Geoserver-users] WMS layers and markers
my application use "layers" and "markers".
Now I open a new browser windows with a WMS like this:
window.open('http://localhost:8080/geoserver/wms?bbox=263422.831249467,
3869554.162498004,1362062.5437611928,5284838.087541916&styles=&minScale=58835000000&
Format=application/openlayers&request=GetMap&layers='+map.layers[0].name +
'&width=2977&height=2050&srs=EPSG:4326','mappa','width=500,height=500
,toolbar=yes, location=no,
status=yes,menubar=yes,scrollbars=yes,resizable=yes');
and this works fine! with:
1. layers='+map.layers[0].name
2. styles=&minScale=58835000000
Now, I need to "extend" this wms with "MARKERS" info.
In my javascript I've defined an "array" of markers like this:
  function addMarker2(objRef, id){ // alert("addMarker2");
     alert("objRef.value="+objRef.value);
           var testo="";
           var tipovalore="";
           var tipovalore2="";
            var numdati=103;
           var_objRef=objRef;
            var_id=id;
           if(livello_scelta=="REGIONE")numdati=20;
           else if (livello_scelta=="AREA") numdati=4;
           else numdati=103;
           popup=new Array();
              arr_query= new Array();
            arr_query[0]= new Array();
           for(w=1; w<=103; w++){ //Numero province 103 lo imposto a 103 e
lo ricompatto in seguito
              arr_query[w]= new Array();
              for(h=0;h<20;h++){
                 arr_query[w][h]= null;
              popup[w]= new OpenLayers.Popup("chicken",
                                      new OpenLayers.LonLat(9.07,39.13),
                                      new OpenLayers.Size(200,80),//100
                                      "Provincia: <br>CODICE ISTAT:",
                                      true);
                         if (!objRef.checked){ //Se รจ un unchecked (l'ho
dececcato)
                                var cancella=null;
                                var arr_temp = new Array();
                                var arr_temp2 = new Array();
                                var arr_temp3 = new Array();
                                 for(y=0; y< marker_layers.length ; y++){
                                     if(marker_layers[y]!=objRef.value) {
                         arr_temp.push(markers_arr[y]);
                         arr_temp2.push(marker_layers[y]);
                         arr_temp3.push(popup_arr[y]);
                   }else{
                     cancella=y;
               map.removeLayer(markers_arr[cancella]);
               markers_arr=arr_temp;
               marker_layers=arr_temp2;
               popup_arr=arr_temp3;
            }else{
       marker_layers.push(objRef.value);
Now, the question is... Can I invoke the WMS with layer and marker
toghether?
Thanks in advance,
Jack
I need to open a new windows with "italy" <-- layer
AND the markers (yellow circles), together!
http://www.nabble.com/file/p15353924/layer%2Bmarkers.jpg
View this message in context: http://www.nabble.com/WMS--layers-and-markers-tp15353924p15353924.html
toghether?
Almost: you may try adding some "inline features" via SLD (see http://docs.codehaus.org/display/GEOSDOC/InLineFeature+Usage).
    Luca Morandini
www.lucamorandini.it
