[Geoserver-users] WMS "Library Mode" request
Hi users.
Sorry for the "doubled" post, the first one is in moderation so I'm
not sure that should be published or banned).
I'm trying to build a geoserver "library mode" request, using info
from this urls:
http://www.geo-solutions.it/blog/dynamic-wms-styling-with-geoserver-sld-and-library-mode/
and
http://docs.geoserver.org/latest/en/user/styling/sld-working.html#sld-library-mode
I've build an url like this:
http://localhost:8080/geoserver/URBINO/wms?layers=URBINO:VPARTICELLE,URBINO:GTCTFAB&styles=CATPARTICELLE,ruleCATBASEFABBRICATI&bbox=...&width=512&height=512&srs=EPSG:3004&format=image/png&service=wms&version=1.1.1&request=GetMap&SLD_BODY=
where SLD_BODY is something like
"<NamedLayer><Name>URBINO:GTCTFAB</Name>
<UserStyle><Name>ruleCATBASEFABBRICATI</Name>..." and it's perfectly
valid "per se" (i've made separate tests.
So basically what I've build is a request that define two layers and two styles.
The first style is defined as a geoserver style
The second style is NOT defined as a geoserver style, but is an
"UserStyle" inside SLD_BODY.
The result of the request is a Service
Exception:"Java.lang.ArrayIndexOutOfBoundsException: 1 1"
Note that I've tried to play with STYLES param, using as example the
string "styles=CATPARTICELLE," (note the last comma) with the same
results.
A request with "styles=CATPARTICELLE," and WITHOUT SLD_BODY works
well, but of course the second layer uses the default style.
A request without SLD_BODY and "styles=CATPARTICELLE" (no comma here)
fails, as I may expect.
Another thing: the same request works if I remove the 'CATPARTICELLE'
style from geoserver and add the same xml inside the request as
UserStyle in SLD_BODY.
Any suggestions?
Thanks for any kind of help.
Diego Guidi
I also couldn't get the library mode to work as described (or at least how I understand it), but I did get it to work by putting all of the layers/styles within the SLD_BODY. Most of the layers use a named style, but the layer "spr_ms_..." uses a UserStyle.
http://mybox/geoserver/cei/wms?SLD_BODY=&lt;StyledLayerDescriptor&gt;&lt;NamedLayer&gt;&lt;Name&gt;cei:mexicarib&lt;/Name&gt;&lt;NamedStyle&gt;&lt;Name&gt;gray\_polys\_hvy\_fill&lt;/Name&gt;&lt;IsDefault&gt;0&lt;/IsDefault&gt;&lt;/NamedStyle&gt;&lt;/NamedLayer&gt;&lt;NamedLayer&gt;&lt;Name&gt;cei:canada&lt;/Name&gt;&lt;NamedStyle&gt;&lt;Name&gt;gray\_polys\_hvy\_fill&lt;/Name&gt;&lt;IsDefault&gt;0&lt;/IsDefault&gt;&lt;/NamedStyle&gt;&lt;/NamedLayer&gt;&lt;NamedLayer&gt;&lt;Name&gt;cei:states&lt;/Name&gt;&lt;NamedStyle&gt;&lt;Name&gt;gray\_polys\_hvy\_fill&lt;/Name&gt;&lt;IsDefault&gt;0&lt;/IsDefault&gt;&lt;/NamedStyle&gt;&lt;/NamedLayer&gt;&lt;NamedLayer&gt;&lt;Name&gt;spr\_ms\_0\_20130731&lt;/Name&gt;&lt;UserStyle&gt;&lt;Name&gt;ws\_var4&lt;/Name&gt;&lt;FeatureTypeStyle&gt;&lt;Rule&gt;&lt;RasterSymbolizer&gt;&lt;ColorMap type="intervals"><ColorMapEntry color="#FFFFFF" quantity="0.000001" opacity="0"/><ColorMapEntry color="#99FF99" quantity="0.5"/><ColorMapEntry color="#FFFF99" quantity="0.7"/><ColorMapEntry color="#FF6666" quantity="1" /></ColorMap></RasterSymbolizer></Rule></FeatureTypeStyle></UserStyle></NamedLayer><NamedLayer><Name>cei:states</Name><NamedStyle><Name>gray_polys_hvy</Name><IsDefault>0</IsDefault></NamedStyle></NamedLayer></StyledLayerDescriptor>&BGCOLOR=0x99CCFF&FORMAT=image/png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG:105002&BBOX=-1248229.0136719,-1258485.8535156,2864599.0136719,1375213.8535156&WIDTH=773&HEIGHT=495
Good Luck,
Steve
On 3/27/2014 12:09 PM, Diego Guidi wrote:
Hi users.
from this urls:
and
results.
Any suggestions?
Diego Guidi
Geoserver-users mailing list
On Thu, Mar 27, 2014 at 5:09 PM, Diego Guidi <diegoguidi@anonymised.com> wrote:
Hi users.
from this urls:
and
styles.
results.
Any suggestions?
Looks like a bug to me, please open a ticket on jira with some sld and
sample requests
to reproduce
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Thu, Mar 27, 2014 at 6:02 PM, Stephen Crawford <src176@anonymised.com> wrote:
It worked :slight_smile:
Looks an acceptable solution to me, thanks.
Anyway, I hope to fill an issue with sample data soon.
Diego Guidi
Issue created: http://jira.codehaus.org/browse/GEOS-6418
ยทยทยท
Looks like a bug to me, please open a ticket on jira with some sld and sample requests
to reproduce
