[Geoserver-users] WMS output format restrictions
Hi!
Is there a way to restrict output formats in WMS mode ? For example, I want to block jpeg and png output and allow, let’s say, png8 and svg.
Thank you very much!
Internet Explorer 8 makes surfing easier. Get it now!
On Tue, Jul 14, 2009 at 7:57 AM, Mister Anonyme<benetage@anonymised.com> wrote:
Hi!
to block jpeg and png output and allow, let's say, png8 and svg.
I don't know if this is possible, but why would you want to do this?
As a server owner I want as many clients as possible to connect to my
maps, otherwise why use an open standard at all?
Ian
Ian Turton
http://www.geotools.org
http://pennspace.blogspot.com/
Hi All,
  I posted a similar question a while back. The reason for us, Ian,
is that we are very heavily limited from a network traffic standpoint at one
of our remote facilities. We require the ability to constrain requests to,
e.g. png8 so that maps will be pulled up in thick clients in seconds, not
minutes. ArcGIS is our thick client that was limiting us, which we couldn't
figure out how to force a png8 request without having the server appear to
only offer that as an option.
  When I posted the question, the best suggestion I got was to save
the WMS capabilites document, modify it, and post it on a static server. If
you still wanted it to be dynamic, you could combine a cron job with cURL
and some awk or perl to periodically update the static capabilities document
for you. If I weren't running a Windows server, I would have already done
this for us in house... .
See conversation below:
Steve
Stephen Mather, GIS Manager
Cleveland Metroparks
4101 Fulton Pkwy
Cleveland, OH 44144
svm@anonymised.com
Phone: (216) 635-3243
FAX: (216) 635-3286
Stephen V. Mather ha scritto:
Hi All.
    Is there any way to control the default image type for a given
service? We've got some remote users with a slow network using a thick
client to access our GeoServer WMS. I'd like to force it to serve PNG8
to reduce the network traffic, and I don't see anything on the client
side that allows me to do that (thick in two ways, I suppose). I'm
hoping I can limit the capabilities for the service of images, in the
same way that I can reduce the number of coordinate systems served.
Any ideas?
We have no switch to control the default wms output format... Actually
there is no such a thing as a "default format", format=xxx is required
by WMS. But I guess the client would end up requesting only png8 if that
was the only format provided to it?
A quick way to test it is to save the wms capabilities output, hand edit
it, and publish it again using some static file publishing tool (e.g.,
you can put it into the www directory of your GeoServer data dir and reach
it at .../geoserver/www/myAmendedCapsFile.xml)
-----Original Message-----
Sent: Tuesday, July 14, 2009 9:59 AM
To: Mister Anonyme
Subject: Re: [Geoserver-users] WMS output format restrictions
Hi!
I want to block jpeg and png output and allow, let's say, png8 and
svg.
I don't know if this is possible, but why would you want to do this? As a
server owner I want as many clients as possible to connect to my maps,
Ian
Ian Turton
Enter the BlackBerry Developer Challenge
This is your chance to win up to $100,000 in prizes! For a limited time,
vendors submitting new applications to BlackBerry App World(TM) will have
the opportunity to enter the BlackBerry Developer Challenge. See full prize
details at: http://p.sf.net/sfu/Challenge
Geoserver-users mailing list Geoserver-users@lists.sourceforge.net
Exactly, same with us.
Static page… I don’t like it, because some clients will try it anyway (custom code).
I can see that I have only two options left: modify source code or create a proxy that will validate the format before forwarding the request to the geoserver.
I think it would be a nice feature to be able to activate/deactivate some output formats. PNG8 is much smaller than PNG and is nicer than JPG.
Thanks guys!
To: ijturton@anonymised.com; benetage@anonymised.com
CC: geoserver-users@lists.sourceforge.net
Subject: RE: [Geoserver-users] WMS output format restrictions
Date: Tue, 14 Jul 2009 12:38:42 -0400
Hi All,
minutes. ArcGIS is our thick client that was limiting us, which we couldn’t
for you. If I weren’t running a Windows server, I would have already done
this for us in house… .
Steve
4101 Fulton Pkwy
Cleveland, OH 44144
svm@anonymised.com
FAX: (216) 635-3286
Hi All.
service? We’ve got some remote users with a slow network using a thick
client to access our GeoServer WMS. I’d like to force it to serve PNG8
to reduce the network traffic, and I don’t see anything on the client
side that allows me to do that (thick in two ways, I suppose). I’m
Any ideas?
We have no switch to control the default wms output format… Actually
there is no such a thing as a “default format”, format=xxx is required
it at …/geoserver/www/myAmendedCapsFile.xml)
To: Mister Anonyme
On Tue, Jul 14, 2009 at 7:57 AM, Mister Anonyme<benetage@anonymised.com…> wrote:
Hi!
svg.
I don’t know if this is possible, but why would you want to do this? As a
Ian
Ian Turton
vendors submitting new applications to BlackBerry App World™ will have
We are your photos. Share us now with Windows Live Photos.
Hi
Would you guys want to use something similar to mod_rewrite, but for
Tomcat, for changing the output format from an incoming GetMap request
to png8?
Something like this:
http://tuckey.org/urlrewrite/
Alex
On Tue, Jul 14, 2009 at 11:13 AM, Mister Anonyme<benetage@anonymised.com> wrote:
Static page... I don't like it, because some clients will try it anyway
(custom code).
geoserver.
Thanks guys!
Hi All,
one
couldn't
If
document
Steve
4101 Fulton Pkwy
Cleveland, OH 44144
svm@anonymised.com
FAX: (216) 635-3286
>> Hi All.
>> Any ideas?
> reach
To: Mister Anonyme
wrote:
> Hi!
> svg.
Ian
Ian Turton
prize
Thanks so much… It works flawlessly with urlrewrite!
Date: Tue, 14 Jul 2009 11:23:28 -0600
To: benetage@anonymised.com
CC: svm@anonymised.com; ijturton@anonymised.com; geoserver-users@lists.sourceforge.net
Hi
to png8?
Alex
On Tue, Jul 14, 2009 at 11:13 AM, Mister Anonymebenetage@anonymised.com wrote:
(custom code).
geoserver.
Thanks guys!
Hi All,
one
couldn’t
If
document
Steve
4101 Fulton Pkwy
Cleveland, OH 44144
svm@anonymised.com
FAX: (216) 635-3286
Hi All.
Any ideas?
reach
To: Mister Anonyme
On Tue, Jul 14, 2009 at 7:57 AM, Mister Anonymebenetage@anonymised.com
wrote:
Hi!
svg.
Ian
Ian Turton
prize
Create a cool, new character for your Windows Live™ Messenger. Check it out
Hello,
I would like to restrict output file formats (WMS) to only :
- JPEG
- GIF
- PNG
- PNG8
Anyone has an example how to use urlrewrite with GeoServer ?
Thanks for any help.
Robin
Mister Anonyme wrote:
Thanks so much... It works flawlessly with urlrewrite!
Hi
to png8?
Alex
> (custom code).
create a
the
> geoserver.
some
> Thanks guys!
>> From: svm@anonymised.com
>> Hi All,
at
>> one
to,
not
>> couldn't
appear to
server.
>> If
cURL
>> document
done
>> Steve
>> 4101 Fulton Pkwy
>> Cleveland, OH 44144
>> svm@anonymised.com
>> FAX: (216) 635-3286
>> >> Hi All.
thick
PNG8
client
the
>> >> Any ideas?
Actually
required
that
edit
(e.g.,
>> > reach
>> Cheers
>> Andrea
>> From: Ian Turton [mailto:ijturton@anonymised.com]
>> To: Mister Anonyme
>> wrote:
>> > Hi!
example,
>> > svg.
As a
>> Ian
>> Ian Turton
time,
have
>> prize
>> _______________________________________________
>> https://lists.sourceforge.net/lists/listinfo/geoserver-users
time,
have
prize
_________________________________________________________________
http://go.microsoft.com/?linkid=9656621
prize
View this message in context: http://old.nabble.com/WMS-output-format-restrictions-tp24478077p29601227.html
