[Not sure if my original post went through, sorry for the repost if it did]
We've successfully set up a rather large and complex set of shapefiles
(about 8GB total, some files >1GB not memory mapped) that are served
by Geoserver as a WMS.
However, we are wondering, are shapefiles the most efficient data
source, performance wise? Or should we look into using PostGIS, or
something else?
David
something else?
It depends
If you are using GeoServer 1.6.0-rc2, and you're not using significant
attribute filtering, shapefiles should be some 2-10 times faster than
Postgis (and Mysql as well) when you're displaying the whole data
set, and more or less on par if you're displaying a small part of it,
provided geoserver managed to create the spatial indexes.
For shapefiles this big geoserver may not be able to (see
http://jira.codehaus.org/browse/GEOT-1498) but you may be able
to create them using the MapServer shptree utility.
If, on the other side, you're doing significant attribute filtering
(stuff like, display only major roads at a certain scale, that is,
you're using attributes to reduce the amount of geometries to be
displayed), then postgis is to be preferred.
Of course a dbms is the preferred solution also if you're going to
use WFS-T against your data.
Ah, if you're using GeoServer 1.5.x series or older, I warmly
suggest you upgrade to 1.6.0, shapefile rendering is a lot faster there.
Hope this helps
something else?
I forgot to add one thing. Certain options for the jvm running GeoServer
make a lot of difference performance wise. See the "GeoServer in production" guide:
http://docs.codehaus.org/display/GEOSDOC/6+GeoServer+in+Production+Environment
>> something else?
production" guide:
Thanks. Our current setup is Geoserver 1.6.0-beta2 running standalone
webserver with jre1.6. We're only serving static data, so WFS-T is not
necessary. We've used shptree were necessary, as well. I think we'll
have to start playing with SLD transparency and antialiasing next. Our
Geoserver jre setup is already setup to use about 500MB of stack
space, which seems a bit much, but at least it's working quite well
that way.
I had a look at
http://www.foss4g2007.org/presentations/view.php?abstract_id=120 which
was very helpful and answered a lot of questions (although I really
think it should be made available as a PDF, I had to install
OpenOffice just to read it -- email me to get a pdf I made out of it).
Looking forward to see how much we're able to squeeze out
David
