[Geoserver-users] WMS Raster Interpolation - Data vs Rendered Image
[For some reason, SourceForge has again posted my response as a blank / empty message. So, I am just submitting this again for the record, in case someone else is researching this in the future. Sorry for any double e-mails to those subscribed to the list].
Thanks for confirming my suspicions. I know there would be some development work, but I hope you agree the interpolation should really be done on the data, not the resulting RGB image. As Jody pointed out, this is really what you want for elevation data, etc. Should I / may I open a JIRA as a Feature Request just to log this for the future?
In the interim, I have been able to accomplish this, at least tentatively, for my own purposes and want to see if you see any holes in my approach:
Here is output from GeoServer … and you can compare to my previous screen shots in this thread:
http://i.imgur.com/twqDa0r.png
http://imgur.com/twqDa0r
You’ll notice this is the Arc_Sample precip layer with the DATA interpolated, instead of the IMAGE.
Thus far, I have implemented this as a Custom Rendering Transformation WPS that does the following:
  1. Takes a GridCoverage2D along with output bounding box, width, and height as parameters.
  2. Crops the input GridCoverage2D to the output bounding box.
  3. Scales (within limits) the cropped GridCoverage2D based on its size compared to the size of the output width/height.
  4. Applies Bilinear interpolation while scaling in #3.
  5. Returns a scaled and bilinear interpolated GridCoverage2D to which a ColorMap is then applied in the SLD.
Any major holes in my approach? Things to consider or check?
Obviously I want to add some more input validation, etc.
One immediate thing I see is the need to perhaps crop a little larger than my output BBOX so I don’t see issues with discrepancies along tile boundaries.
Something else I thought of is that the WPS-style approach also lets people choose a per-layer WMS interpolation method, as has been requested in other threads.
Mike Grogan
Ciao Mike,
I am interested in fixing this for good.
As Andrea pointed out it some effort is required, however I believe
this is strategic for GeoServer to properly render environmental data
with high order interpolation. As such, could you create a jira for
this problem and make available the code you are playing with?
Next week I will talk to the guys in the office and come up with a
tentative plan to fix this on master.
Thanks for taking the time to look into this.
Simone Giannecchini
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Fri, Apr 18, 2014 at 3:38 PM, Mike Grogan <d.michael.grogan@anonymised.com> wrote:
Here is output from GeoServer ... and you can compare to my previous screen
You'll notice this is the Arc_Sample precip layer with the DATA
as parameters.
my output BBOX so I don't see issues with discrepancies along tile
boundaries.
threads.
Mike Grogan
Learn Graph Databases - Download FREE O'Reilly Book
"Graph Databases" is the definitive new guide to graph databases and their
applications. Written by three acclaimed leaders in the field,
this first edition is now available. Download your free book today!
http://p.sf.net/sfu/NeoTech
Geoserver-users mailing list
Yes, I will create the JIRA, Simone. I am just seeing this today as I have been away for a few days unexpectedly, so it may take just a bit to do so.
Mike
On Thu, Apr 24, 2014 at 6:58 AM, Simone Giannecchini <simone.giannecchini@anonymised.com…> wrote:
Ciao Mike,
Simone Giannecchini
@simogeo
Founder/Director
    as parameters.
boundaries.
threads.
Mike Grogan
Learn Graph Databases - Download FREE O’Reilly Book
“Graph Databases” is the definitive new guide to graph databases and their
JIRA opened as:
https://jira.codehaus.org/browse/GEOS-6464
Improvement - Interpolation of data instead of images for non-RGBA rasters
  • Mike
On Mon, Apr 28, 2014 at 3:53 PM, Mike Grogan <d.michael.grogan@anonymised.com> wrote:
From my initial effort, my early recommendation would be to have this available as some type of rendering transformation instead of implementing it for all layers coming from the WMS. This would allow someone to “turn on” and “turn off” the interpolation. That describes the (very simple) code I have been playing with. I will attach that to the JIRA when I create it.
Mike
On Thu, Apr 24, 2014 at 6:58 AM, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Ciao Mike,
Simone Giannecchini
@simogeo
Founder/Director
On Fri, Apr 18, 2014 at 3:38 PM, Mike Grogan <d.michael.grogan@anonymised.com…> wrote:
    as parameters.
boundaries.
threads.
Mike Grogan
Has there been any progress made on this? If not, we might have to bite the
bullet and get an arcGIS server license.
View this message in context: http://osgeo-org.1560.x6.nabble.com/WMS-Raster-Interpolation-Data-vs-Rendered-Image-tp5133991p5282497.html
I have vague memories that we did move the interpolation, but I cannot confirm.
Just as an observation, in case your tests show it’s not the case, I’d suggest you check the GeoServer
support providers to get a quote for a fix, I have a feeling it might be less expensive than a ArcGis license :wink:
http://geoserver.org/support/
Geoserver-users@anonymised.com.382…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
We had to move Jira when Codehaus shut down, it’s here now: https://osgeo-org.atlassian.net/browse/GEOS-6464
Please make sure messages cc the user list too (I brought the conversation back there with this message.
On Tue, Aug 30, 2016 at 5:36 PM, Devin Eyre <Devin.Eyre@anonymised.com> wrote:
There was a jira link on the nabble website that went to something that wasn’t there any longer.
Did that get moved somewhere else, or are you no longer using jira?
From: andrea.aime@anonymised.com <andrea.aime@anonymised.com> on behalf of Andrea Aime <andrea.aime@anonymised.com>
Sent: Tuesday, August 30, 2016 8:14 AM
To: Devin Eyre
Cc: GeoServer Mailing List List
Subject: Re: [Geoserver-users] WMS Raster Interpolation - Data vs Rendered Image
On Fri, Aug 26, 2016 at 10:15 PM, deveyre <devin.eyre@anonymised.com…7803…> wrote:
Geoserver-users@anonymised.comrge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks for your help, Andrea. I discovered that in order to make bilinear or bicubic interpolation for rasters work, you need to change the setting in the WMS settings, not the individual layer settings, and now it is working as desired.
From: andrea.aime@anonymised.com. andrea.aime@anonymised.com on behalf of Andrea Aime <andrea.aime@anonymised.com1107…>
Sent: Tuesday, August 30, 2016 10:45 AM
To: Devin Eyre; GeoServer Mailing List List
On Tue, Aug 30, 2016 at 5:36 PM, Devin Eyre <Devin.Eyre@anonymised.com…7803…> wrote:
From: andrea.aime@anonymised.com… <andrea.aime@anonymised.com> on behalf of Andrea Aime <andrea.aime@anonymised.com>
To: Devin Eyre
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
