[Geoserver-users] WMS request returns empty layer list
Geoserver 2.7.4, Tomcat7, Ubuntu 14, Java 1.7
Hello,
The setup is very simple:
1 Workspace
1 Store: A PostGis table with point geometry
1 Layer from the above Store, enabled and advertised
WMS Services are global only and activated.
Layer preview in Geoserver-OpenLayers is fine.
But when I try to access the layer in a client, then the layer list is empty. I tried to connect to Geoserver from both QGis and Mapbender - same result: The connection to Geoserver works but the list of layers that is returned to the client by Geoserver is empty, although the layer is enabled and advertised in the layer settings. QGis and Mapbender work fine with other servers, so the problem is with Geoserver.
The same problem occurred also with a shape-file store in an earlier attempt - I started over from scratch after repeated failures to get this to work by following the simple tutorials in the documentation step-by-step, without success.
Any help is very appreciated, thank you.
Henning
the problem appears to be local to your computer, I’ve just succesfully
loaded layers using QGis from a local 2.8.3 installation, and also from
this 2.9.x demo server:
http://demo.geo-solutions.it/geoserver/
Wondering, by any chance, did you setup layer level security and restricted
it to the admin user? That would explain why you can get the layers in
the preview, but your capabilities documents (with no authentication) are otherwise empty
On Fri, May 20, 2016 at 12:39 PM, Henning Lorenz <henning.lorenz@anonymised.com> wrote:
Hello,
1 Workspace
Henning
Mobile security can be enabling, not merely restricting. Employees who
bring their own devices (BYOD) to work are irked by the imposition of MDM
restrictions. Mobile Device Manager Plus allows you to control only the
apps on BYO-devices by containerizing them, leaving personal data untouched!
https://ad.doubleclick.net/ddm/clk/304595813;131938128;j
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
