I encountered an issue that I always get a blank WMS map if I request the
map in EPSG:900913, the problem seems to be Postgres specific because if I
use shapefile datastore with the same data the map shows up perfect.
What version of GeoServer are you running? Are you running from trunk,
or a 1.6.x or earlier release?
Yingqi wrote:
All,
