Hi geoserver list,
i got an exception when requesting a GetLegendGraphic. First i was trying with a mapclient and got no legend. When looking into the log i found this exception:
--------- 8< -------------------------------------------
20 Okt 14:13:11 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/wms?REQUEST=GetLegendGraphic&VERSION=1.0.0&FORMAT=image/png&WIDTH=20&HEIGHT=400&LAYER=sde:GEOLOGIE.V_GUEK_GUEK300P” “Mozilla/5.0 (Windows; U; Windows NT 5.2; de; rv:1.8.1.12) Gecko/20080201 Firefox/2.0.0.12” “”
20 Okt 14:13:11 WARN [geoserver.ows] -
java.lang.NullPointerException
at org.geotools.renderer.style.SLDStyleFactory.getTexturePaint(SLDStyleFactory.java:1105)
at org.geotools.renderer.style.SLDStyleFactory.getPaint(SLDStyleFactory.java:1030)
at org.geotools.renderer.style.SLDStyleFactory.createPolygonStyle(SLDStyleFactory.java:376)
at org.geotools.renderer.style.SLDStyleFactory.createStyleInternal(SLDStyleFactory.java:330)
I styled this polygon-layer with an SLD. Inside the SLD i used about 30 different bitmaps (jpeg and png) for styling of some hatching and dot fill patterns. I referenced them as externalGraphics.
After getting the exception i tried a plain browser-http GetLegendGraphic with the same success. But the strange thing is: The GetMap is beeing served without exception.
I’m using geoserver 1.6.3 with ArcSDE Backend on a WIN2003 Server platform, java 1.5/tomcat 5.5.26. Could you please take a look at the stack:
2008-10-20 14:01:46,409 [Thread-1] INFO org.apache.struts.tiles.TilesPlugin - Tiles definition factory loaded for module ‘’.
20 Okt 14:01:48 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: C:\Programme\Apache_Software_Foundation\apache-tomcat-5.5.26\instanzen\tomcat1\webapps\geoserver\data
20 Okt 14:01:48 WARN [referencing.factory] - Axis elements found in a wkt definition, the force longitude first axis order hint might not be respected:
PROJCS[“WGS84 / Simple Mercator”, GEOGCS[“WGS 84”, DATUM[“WGS_1984”, SPHEROID[“WGS_1984”, 6378137.0, 298.257223563]], PRIMEM[“Greenwich”, 0.0], UNIT[“degree”, 0.017453292519943295], PROJECTION[“Mercator_1SP_Google”], PARAMETER[“latitude_of_origin”, 0.0], PARAMETER[“central_meridian”, 0.0], PARAMETER[“scale_factor”, 1.0], PARAMETER[“false_easting”, 0.0], PARAMETER[“false_northing”, 0.0], UNIT[“m”, 1.0], AXIS[“x”, EAST], AXIS[“y”, NORTH], AUTHORITY[“EPSG”,“54004”]]
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
20 Okt 14:01:49 INFO [geoserver.global] - Loading feature type ‘geo1mig_oracle:::FFH_SDO’ (layer 1/8)
20 Okt 14:01:49 WARN [geotools.factory] - Can’t load a service for category “DataStoreFactorySpi”. Cause is “NoClassDefFoundError: org/geotools/data/DataStoreFactorySpi”.
20 Okt 14:01:51 INFO [geoserver.global] - Loading feature type ‘geo1mig_oracle_wasser:::KA_KOM_EINL_SDO’ (layer 2/8)
20 Okt 14:01:52 INFO [geoserver.global] - Loading feature type ‘geo1mig_sde:::NATUR.FFH’ (layer 3/8)
20 Okt 14:01:52 WARN [arcsde.pool] - No database name specified
20 Okt 14:01:55 INFO [geoserver.global] - Loading feature type ‘geo1mig_sde:::RKH.HAUPT’ (layer 4/8)
20 Okt 14:01:56 INFO [geoserver.global] - Loading feature type ‘geo1mig_sde_guek300:::GEOLOGIE.V_GUEK_GUEK300L’ (layer 5/8)
20 Okt 14:01:56 WARN [arcsde.pool] - No database name specified
20 Okt 14:01:56 INFO [geoserver.global] - Loading feature type ‘geo1mig_sde_guek300:::GEOLOGIE.V_GUEK_GUEK300P’ (layer 6/8)
20 Okt 14:01:57 INFO [geoserver.global] - Loading feature type ‘geo1mig_SDE_hydgeoview:::HYDGEO.PV_TWSHQS’ (layer 7/8)
20 Okt 14:01:57 WARN [arcsde.pool] - No database name specified
20 Okt 14:01:58 INFO [geoserver.global] - Loading feature type ‘geo1mig_SDE_WASSER:::WASSER.KA_KOM_EINL’ (layer 8/8)
20 Okt 14:01:58 WARN [arcsde.pool] - No database name specified
20 Okt 14:02:01 WARN [arcsde.pool] - No database name specified
2008-10-20 14:02:06,300 [TP-Processor3] INFO org.apache.struts.tiles.TilesRequestProcessor - Tiles definition factory found for request processor ‘’.
2008-10-20 14:02:06,972 [TP-Processor3] INFO de.conterra.mapclient.businesstier.mapprocessing.IMCImageMergerJAI - JAI - Tilesize is java.awt.Dimension[width=256,height=256]
2008-10-20 14:02:06,972 [TP-Processor3] INFO de.conterra.mapclient.businesstier.mapprocessing.IMCImageMergerJAI - Maximal 8 threads merging concurrently.
20 Okt 14:02:07 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/wms?REQUEST=GetCapabilities&SERVICE=WMS” “Java/1.5.0_15” “”
20 Okt 14:02:07 INFO [responses.helpers] - Supported JAIMapResponse’s MIME Types: [image/jpeg]
20 Okt 14:02:07 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/wms?REQUEST=GetCapabilities&SERVICE=WMS” took 563ms
2008-10-20 14:02:07,675 [TP-Processor3] INFO de.conterra.suite.adapter.wms.WMService - setServiceID(20)
2008-10-20 14:02:07,675 [TP-Processor3] WARN de.conterra.mapclient.businesstier.mapprocessing.IMCMapBuilder - no string field found while constructing #ALL#-queryField for layer [GEOLOGIE.V_GUEK_GUEK300P_Type, 2000]
2008-10-20 14:02:07,675 [TP-Processor3] WARN de.conterra.mapclient.businesstier.mapprocessing.IMCMapBuilder - no string field found while constructing #ALL#-queryField for layer [GEOLOGIE.V_GUEK_GUEK300L_Type, 2001]
2008-10-20 14:02:07,691 [TP-Processor3] INFO de.conterra.mapclient.businesstier.mapprocessing.IMCMapBuilder - No overview map information present.
2008-10-20 14:02:07,706 [TP-Processor3] INFO de.conterra.mapclient.businesstier.mapaccess.acetateimage.IMCAcetateRenderer - constructor(outputPath="C:\Programme\mapClient\webapp\output", outputUrl = “http://localhost/mapClient/output/”)
2008-10-20 14:02:07,706 [TP-Processor3] INFO de.conterra.mapclient.businesstier.mapaccess.acetateimage.IMCAcetateRenderer - configureLayers
2008-10-20 14:02:07,706 [TP-Processor3] INFO de.conterra.mapclient.businesstier.mapaccess.acetateimage.IMCAcetateRenderer - setLayerVisibility
2008-10-20 14:02:07,706 [TP-Processor3] INFO de.conterra.mapclient.businesstier.mapaccess.generic.IMCCanvasDatasource - setDotsPerInch
2008-10-20 14:02:07,706 [TP-Processor3] INFO de.conterra.mapclient.businesstier.mapaccess.acetateimage.IMCAcetateRenderer - setLegendTitle
2008-10-20 14:02:07,706 [TP-Processor3] INFO de.conterra.mapclient.businesstier.mapaccess.generic.IMCCanvasDatasource - setImageHeight(0)
2008-10-20 14:02:07,706 [TP-Processor3] INFO de.conterra.mapclient.businesstier.mapaccess.generic.IMCCanvasDatasource - setImageWidth(0)
2008-10-20 14:02:07,706 [TP-Processor3] INFO de.conterra.mapclient.businesstier.mapaccess.generic.IMCCanvasDatasource - setSRS
2008-10-20 14:02:07,706 [TP-Processor3] INFO de.conterra.mapclient.businesstier.mapaccess.acetateimage.IMCAcetateRenderer - setImageFormat(image/png)
2008-10-20 14:02:07,706 [TP-Processor3] INFO de.conterra.mapclient.businesstier.mapaccess.acetateimage.IMCAcetateRenderer - setImageFormat successful
2008-10-20 14:02:07,706 [TP-Processor3] INFO de.conterra.mapclient.webtier.struts.actions.InitSDIViewerConfigurationAction - mapClient-Properties wurden noch nicht geladen. Lade mapClient-Properties…
2008-10-20 14:02:08,050 [TP-Processor2] INFO de.conterra.mapclient.businesstier.mapaccess.generic.IMCCanvasDatasource - setImageHeight(576)
2008-10-20 14:02:08,050 [TP-Processor2] INFO de.conterra.mapclient.businesstier.mapaccess.generic.IMCCanvasDatasource - setImageWidth(910)
2008-10-20 14:02:08,050 [TP-Processor2] INFO de.conterra.mapclient.businesstier.mapaccess.generic.IMCCanvasDatasource - setExtent((3469665.0, 5531574.0)-(3509329.0, 5565226.0))
2008-10-20 14:02:08,050 [TP-Processor2] INFO de.conterra.mapclient.businesstier.mapaccess.generic.IMCCanvasDatasource - setSRS
2008-10-20 14:02:09,331 [TP-Processor2] INFO de.conterra.mapclient.businesstier.mapaccess.generic.IMCCanvasDatasource - setExtent((3462914.2569444445, 5531574.0)-(3516079.7430555555, 5565226.0))
2008-10-20 14:02:09,331 [TP-Processor2] INFO de.conterra.mapclient.businesstier.mapaccess.generic.IMCCanvasDatasource - setSRS
2008-10-20 14:02:09,331 [Thread-39] INFO de.conterra.mapclient.businesstier.mapaccess.acetateimage.IMCAcetateRenderer - fitLayersToExtent
2008-10-20 14:02:09,331 [Thread-39] INFO de.conterra.mapclient.businesstier.mapaccess.acetateimage.IMCAcetateRenderer - doRefresh
2008-10-20 14:02:09,331 [Thread-39] INFO de.conterra.mapclient.businesstier.mapaccess.acetateimage.IMCAcetateRenderer - acetatesPresent → false
20 Okt 14:02:09 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/wms?SERVICE=WMS&REQUEST=GetMap&VERSION=1.1.1&FORMAT=image%2Fpng&SRS=EPSG%3A31467&LAYERS=sde%3AGEOLOGIE.V_GUEK_GUEK300P%2Csde%3AGEOLOGIE.V_GUEK_GUEK300L&STYLES=GEOLOGIE.V_GUEK_GUEK300P_style%2CGEOLOGIE.V_GUEK_GUEK300L_style&BBOX=3462914.256944%2C5531574%2C3516079.743056%2C5565226&WIDTH=910&HEIGHT=576&TRANSPARENT=TRUE&BGCOLOR=0xFFFFFF” “Java/1.5.0_15” “”
20 Okt 14:02:13 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_7.jpg” “Java/1.5.0_15” “”
20 Okt 14:02:13 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_7.jpg” took 0ms
20 Okt 14:02:13 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_geoid6.png” “Java/1.5.0_15” “”
20 Okt 14:02:13 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_geoid6.png” took 0ms
20 Okt 14:02:14 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_10.jpg” “Java/1.5.0_15” “”
20 Okt 14:02:14 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_10.jpg” took 0ms
20 Okt 14:02:14 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_8.jpg” “Java/1.5.0_15” “”
20 Okt 14:02:14 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_8.jpg” took 0ms
20 Okt 14:02:15 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_3.jpg” “Java/1.5.0_15” “”
20 Okt 14:02:15 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_3.jpg” took 0ms
20 Okt 14:02:15 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_74.jpg” “Java/1.5.0_15” “”
20 Okt 14:02:15 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_74.jpg” took 0ms
20 Okt 14:02:16 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_geoid86.png” “Java/1.5.0_15” “”
20 Okt 14:02:16 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_geoid86.png” took 0ms
20 Okt 14:02:17 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_87.png” “Java/1.5.0_15” “”
20 Okt 14:02:17 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_87.png” took 0ms
20 Okt 14:02:17 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_89.jpg” “Java/1.5.0_15” “”
20 Okt 14:02:17 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_89.jpg” took 0ms
20 Okt 14:02:18 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_88.jpg” “Java/1.5.0_15” “”
20 Okt 14:02:18 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_88.jpg” took 0ms
20 Okt 14:02:18 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_75.jpg” “Java/1.5.0_15” “”
20 Okt 14:02:18 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_75.jpg” took 0ms
20 Okt 14:02:19 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_90.png” “Java/1.5.0_15” “”
20 Okt 14:02:19 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_90.png” took 0ms
20 Okt 14:02:19 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_geoid92.png” “Java/1.5.0_15” “”
20 Okt 14:02:19 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_geoid92.png” took 0ms
20 Okt 14:02:20 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_81.png” “Java/1.5.0_15” “”
20 Okt 14:02:20 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_81.png” took 0ms
20 Okt 14:02:21 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_20.png” “Java/1.5.0_15” “”
20 Okt 14:02:21 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_20.png” took 0ms
20 Okt 14:02:21 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_geoid48.png” “Java/1.5.0_15” “”
20 Okt 14:02:21 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_geoid48.png” took 0ms
20 Okt 14:02:23 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_82.png” “Java/1.5.0_15” “”
20 Okt 14:02:23 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_82.png” took 0ms
20 Okt 14:02:24 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_91.jpg” “Java/1.5.0_15” “”
20 Okt 14:02:24 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_91.jpg” took 0ms
20 Okt 14:02:28 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/wms?SERVICE=WMS&REQUEST=GetMap&VERSION=1.1.1&FORMAT=image%2Fpng&SRS=EPSG%3A31467&LAYERS=sde%3AGEOLOGIE.V_GUEK_GUEK300P%2Csde%3AGEOLOGIE.V_GUEK_GUEK300L&STYLES=GEOLOGIE.V_GUEK_GUEK300P_style%2CGEOLOGIE.V_GUEK_GUEK300L_style&BBOX=3462914.256944%2C5531574%2C3516079.743056%2C5565226&WIDTH=910&HEIGHT=576&TRANSPARENT=TRUE&BGCOLOR=0xFFFFFF” took 18688ms
2008-10-20 14:02:28,019 [TP-Processor2] INFO de.conterra.mapclient.businesstier.mapdata.IMCMap - Merging Time around: 0ms
2008-10-20 14:02:28,019 [TP-Processor2] INFO de.conterra.mapclient.webtier.struts.actions.IMCRefreshMapAction - MapRefreshAction
2008-10-20 14:02:33,019 [TP-Processor3] INFO de.conterra.mapclient.businesstier.mapaccess.acetateimage.IMCAcetateRenderer - getLegendURL
20 Okt 14:02:33 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/wms/GetLegendGraphic?VERSION=1.0.0&FORMAT=image/png&WIDTH=20&HEIGHT=20&LAYER=sde:GEOLOGIE.V_GUEK_GUEK300L” “Mozilla/5.0 (Windows; U; Windows NT 5.2; de; rv:1.8.1.12) Gecko/20080201 Firefox/2.0.0.12” “http://localhost/mapClient/LegendOn.do”
20 Okt 14:02:33 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/wms/GetLegendGraphic?VERSION=1.0.0&FORMAT=image/png&WIDTH=20&HEIGHT=20&LAYER=sde:GEOLOGIE.V_GUEK_GUEK300P” “Mozilla/5.0 (Windows; U; Windows NT 5.2; de; rv:1.8.1.12) Gecko/20080201 Firefox/2.0.0.12” “http://localhost/mapClient/LegendOn.do”
20 Okt 14:02:33 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_5.jpg” “Java/1.5.0_15” “”
20 Okt 14:02:33 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_5.jpg” took 0ms
20 Okt 14:02:33 INFO [geoserver.filters] - Not compressing output for mimetype: image/png
20 Okt 14:02:33 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/wms/GetLegendGraphic?VERSION=1.0.0&FORMAT=image/png&WIDTH=20&HEIGHT=20&LAYER=sde:GEOLOGIE.V_GUEK_GUEK300L” took 156ms
20 Okt 14:02:33 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_geoid9.png” “Java/1.5.0_15” “”
20 Okt 14:02:33 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_geoid9.png” took 0ms
20 Okt 14:02:34 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_11.png” “Java/1.5.0_15” “”
20 Okt 14:02:34 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_11.png” took 0ms
20 Okt 14:02:34 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_geoid19.png” “Java/1.5.0_15” “”
20 Okt 14:02:34 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_geoid19.png” took 0ms
20 Okt 14:02:35 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_24.png” “Java/1.5.0_15” “”
20 Okt 14:02:35 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_24.png” took 0ms
20 Okt 14:02:35 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_geoid27.png” “Java/1.5.0_15” “”
20 Okt 14:02:35 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_geoid27.png” took 0ms
20 Okt 14:02:36 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_28.jpg” “Java/1.5.0_15” “”
20 Okt 14:02:36 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_28.jpg” took 0ms
20 Okt 14:02:36 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_geoid33.png” “Java/1.5.0_15” “”
20 Okt 14:02:36 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_geoid33.png” took 0ms
20 Okt 14:02:37 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_geoid37.png” “Java/1.5.0_15” “”
20 Okt 14:02:37 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_geoid37.png” took 0ms
20 Okt 14:02:37 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_97.jpg” “Java/1.5.0_15” “”
20 Okt 14:02:37 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_97.jpg” took 0ms
20 Okt 14:02:38 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_45.png” “Java/1.5.0_15” “”
20 Okt 14:02:38 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_45.png” took 0ms
20 Okt 14:02:38 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_49.png” “Java/1.5.0_15” “”
20 Okt 14:02:38 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_49.png” took 0ms
20 Okt 14:02:39 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_51.png” “Java/1.5.0_15” “”
20 Okt 14:02:39 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_51.png” took 0ms
20 Okt 14:02:39 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_52.png” “Java/1.5.0_15” “”
20 Okt 14:02:39 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_52.png” took 0ms
20 Okt 14:02:40 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_99.jpg” “Java/1.5.0_15” “”
20 Okt 14:02:40 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_99.jpg” took 0ms
20 Okt 14:02:40 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_55.png” “Java/1.5.0_15” “”
20 Okt 14:02:40 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_55.png” took 0ms
20 Okt 14:02:41 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_103.jpg” “Java/1.5.0_15” “”
20 Okt 14:02:41 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_103.jpg” took 0ms
20 Okt 14:02:41 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_geoid104.png” “Java/1.5.0_15” “”
20 Okt 14:02:41 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_geoid104.png” took 0ms
20 Okt 14:02:42 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_105.jpg” “Java/1.5.0_15” “”
20 Okt 14:02:42 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/bitmaps/geologie_105.jpg” took 0ms
20 Okt 14:02:42 WARN [geoserver.ows] -
at org.geotools.renderer.style.SLDStyleFactory.createStyle(SLDStyleFactory.java:295)
at org.vfny.geoserver.wms.responses.DefaultRasterLegendProducer.produceLegendGraphic(DefaultRasterLegendProducer.java:245)
at org.vfny.geoserver.wms.responses.GetLegendGraphicResponse.execute(GetLegendGraphicResponse.java:81)
at org.geoserver.ows.adapters.ResponseAdapter.getMimeType(ResponseAdapter.java:48)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:616)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:192)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:215)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:69)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:174)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:174)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:874)
at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:665)
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:528)
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:81)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:689)
at java.lang.Thread.run(Thread.java:595)
Thanks
Albrecht
Albrecht Weiser,
E6, GIS Center
Hessische Zentrale für Datenverarbeitung (HZD)
