On Mon, Oct 27, 2014 at 10:13 AM, Ragnvald Larsen <
ragnvald.larsen@anonymised.com> wrote:
Hi there,
I am preparing a wms-t based service related to a coastal areas
emergency response information system. User requested data be provided on a
per month basis. The test service is available here:
http://wms.miljodirektoratet.no/geoserver/kystinfo/wms?service=WMS&version=1.1.0&request=GetMap&layers=kystinfo:fugl&styles=&bbox=-330000.0,6300000.0,1390000.0,9020000.0&width=323&height=512&srs=EPSG:32633&format=application/openlayers
I would have assumed that a request to a wms-t service would provide
default to all data if no date (T=xxxxxxxxx) is provided. Seems like it’s
not.
No, the spec assumes there is a default value if you don't specify any,
which is either "current" (now) or the greatest time you have (in case of
forecasts the two can differ)
Is it possible to set a default time or reduced accuracy default time like
this one: 2014-01/2014-12
I don't think we support such a loose spec, but try adding the day also:
2014-01-01/2014-12-31
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
