[Geoserver-users] WMS XML Output
Hello,
Does anyone know how I can create an XML output with WMS using
getfeatureinfo?
In my search the only solutions I found for WFS. Are there any options to
use mime-type XML for WMS?
Freek
View this message in context: http://www.nabble.com/WMS-XML-Output-tp19457181p19457181.html
GeoServer WMS supports at least two XML formats; KML (aka Google Earth) and SVG. If you need something other than these we will need more information about what you are trying to accomplish.
Hope this helps,
-David Winslow
Freek_01 wrote:
Hello,
getfeatureinfo?
Freek
Freek_01 ha scritto:
Hello,
getfeatureinfo?
You can ask the GetFeatureInfo output to be generated in GML2
Hi Flo,
Yes, we support GML output for GetFeatureInfo operations. Just use "application/vnd.ogc.gml" as the value of the info_format parameter. Here is an example:
http://localhost:8080/geoserver/wms?bbox=-130,24,-66,50&styles=population&format=jpeg&info_format=application/vnd.ogc.gml&request=GetFeatureInfo&layers=topp:states&query_layers=topp:states&width=550&height=250&x=170&y=160
-Justin
David Winslow wrote:
Hope this helps,
-David Winslow
Freek_01 wrote:
Hello,
getfeatureinfo?
Freek
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Justin Deoliveira
Software Engineer, OpenGeo
http://opengeo.org
