Hello
I would like to investigate using XML requests over POST to GeoServer, but I'm stumped by the lack of documentation about it. The WMS standard doesn't say anything about it, the SLD standard brings it up with an example, and I have gathered the schema for XML GetMap request is under the sld folder. But it doesn't answer all concerns:
- How to use XML-encoded request if it's not for SLD styles - e.g. because the request length exceeds GET limits.
- How to pass vendor-specific parameters like CQL_FILTER and TILED.
I know I can pass URL-encoded data in the POST content, but that doesn't excuse not learning about the XML-encoding. It may be Plan B (or Plan A, and XML-encoding becomes Plan B).
Does anyone know of a great web page discussing XML-encoded requests to WMS with examples? I think there ought to be a page on the GeoServer User Guide under Services->WMS about this.
Kind regards
Ugland IT Group AS
Thomas Jahnsen
Developer
Tel: + 47 67 59 28 23
E-mail: thja@anonymised.com
UGLAND IT GROUP AS, Strandveien 13, Pb. 58, 1324 Lysaker, org.nr. 971 058 773
Tlf: +47 67 59 28 10, fax: +47 67 59 28 11, email: firmapost@anonymised.com, internet: www.uglandit.com
Thomas Jahnsen ha scritto:
Hello
request is under the sld folder. But it doesn't answer all concerns: - How to use XML-encoded request if it's not for SLD styles
You don't, it's meant to be used with SLD styles. Or else, I
don't understand your question.
In this case, you can post your GET request as a form, just make
sure to use the proper mime type, application/form-url-encoded,
when posting it.
- How to pass
There is no support for vendor parameters in XML requests.
Nope, there is no such documentation. All there is, is in the
SLD standard.
Andrea Aime
OpenGeo - http://opengeo.org
