[Geoserver-users] wmsgetfeatureinfo only works on polygon boundaries not "centre"
I suppose that it happens because the GetFeatureInfo system was heavily improved to suit as well as possible with all that shows on the map: road widths, sizes and shapes of the symbols. If polygon has no fill there is nothing visible on the map and the current implementation thinks that there is nothing interesting to make queries about. This is probably a case that just did not come into the minds of the developers. Are you willing to file a ticket to Jira?
-Jukka-
Lähettäjä: Ismail, Mark [mailto:mark.ismail@anonymised.com]
Lähetetty: 4. kesäkuuta 2014 10:26
Vastaanottaja: Rahkonen Jukka (Tike); ‘geoserver mailing list (geoserver-users@lists.sourceforge.net)’
Aihe: RE: [Geoserver-users] wmsgetfeatureinfo only works on polygon boundaries not “centre”
Hi
Yes the style had no fill – I tried changing the style to one with fill and the polygon then works correctly
Strange feature – guess I will have to go for a 99% transparent fill !
Mark Ismail
Principal IT Officer
Tel: 0151 443 3021
Knowsley Council ê Westmorland Road ê Huyton ê L36 9GL
Save time – use the IT Service Desk Self Serve Application
From: Rahkonen Jukka (Tike) [mailto:jukka.rahkonen@anonymised.com]
Sent: 03 June 2014 17:15
To: Ismail, Mark; ‘geoserver mailing list (geoserver-users@lists.sourceforge.net)’
Subject: Re: [Geoserver-users] wmsgetfeatureinfo only works on polygon boundaries not “centre”
Interesting. Do you possibly draw only polygon outlines in your styles but not fill at all? If this is the case, would adding a fill change the behaviour?
-Jukka Rahkonen-
Ismail, Mark wrote:
I have some tables recently added to geoserver and wmsgetfeatureinfo only returns a result if I click on the lines which form the polygon perimeter I have checked and the original table has got regions and not line features
Any ideas ?
Mark Ismail
Tel: 0151 443 3021
This e-mail and any attachments are confidential. It may contain privileged information and is intended for the named recipient(s) only. It must not be distributed without consent. If you are not one of the intended recipients, please notify the sender immediately and do not disclose, distribute, or retain this email or any part of it and do not take any action based on it.
Unless expressly stated, opinions in this email are those of the individual sender, and not of Knowsley MBC. Legally binding obligations can only be created for, or be entered into on behalf of, Knowsley MBC by duly authorised officers or representatives.
Knowsley MBC excludes any liability whatsoever for any offence caused, any direct or consequential loss arising from the use, or reliance on, this e-mail or its contents. We believe but do not warrant that this e-mail and any attachments are virus free. You must therefore take full responsibility for virus checking and no responsibility is accepted for loss or damage arising from viruses or changes made to this message after it was sent. Knowsley MBC reserves the right to monitor and/or record all e-mail communications through its network in accordance with relevant legislation.
