Hello to all
Is it possible to force the WMTS tile routine to not create tile files for those places where no feature exist there?
We want to make WMTS tiles for our cities which are spread in the country. We wish it be possible to build tile files just for cities area, and not for whole country. In this way the amount of our files will be reduced and we will be able to make tiles for more resolution levels.
Thanks for your time.
Best regards
Ali Madad
Hi
You should try to use the seeding function of geowebcache which allow to add a bbox as a parameter.
Then you need to call the function for each major city.
Xl
Le 8 sept. 2014 06:34, “mehdi saeedi” <msaeedi50@anonymised.com> a écrit :
Hello to all
Best regards
Ali Madad
Want excitement?
Manually upgrade your production database.
When you want reliability, choose Perforce
Perforce version control. Predictably reliable.
http://pubads.g.doubleclick.net/gampad/clk?id=157508191&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Hi, there’s a little used and poorly documented feature in GWC called a “Request Filter” which which can be used for this.
There’s some documentation about it included in the Schema file for the configuration file: http://geowebcache.org/schema/1.5.3/geowebcache.xsd It’s not the greatest documentation ever, but it should be enough to get you operational.
On 7 September 2014 21:44, xavier lhomme <lhomme.xavier@anonymised.com> wrote:
Hi
Xl
Le 8 sept. 2014 06:34, “mehdi saeedi” <msaeedi50@anonymised.com…> a écrit :
Hello to all
Best regards
Ali Madad
Want excitement?
Want excitement?
Kevin Smith
Junior Software Engineer | Boundless
ksmith@anonymised.com
+1-778-785-7459
@boundlessgeo
