Hello all.
I have three layers. 2 layers is Point and 1 layers Polygon
I create a group layer in the following order: Point layer, Polygon layer, Point layer.
Point layer has SLD is a TextSymbolizer.
When I look at the Preview I want to see what text that covered the polygon below, and it’s not visible, and the text that is visible on top of the polygon.
But I see both text layers. If i use true in polygon SLD, I do not see the two text layers in bounding box of polygon.
Рow to make a text layer on top of the polygon was visible and not visible from below the polygon?
3.2.0-52-generic #78-Ubuntu SMP Fri Jul 26 16:21:44 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
General information about GeoServer
Locks 0
Connections 6
Memory Usage 140 MB
JVM Version Oracle Corporation: 1.7.0_25 (Java HotSpot™ 64-Bit Server VM)
Available Fonts GeoServer can access 309 different fonts. Full list of available fonts
Native JAI true
Native JAI ImageIO true
JAI Maximum Memory 1 GB
JAI Memory Usage 0 KB
JAI Memory Threshold 75.0
Number of JAI Tile Threads 7
JAI Tile Thread Priority 5
ThreadPoolExecutor Core Pool Size 5
ThreadPoolExecutor Max Pool Size 10
ThreadPoolExecutor Keep Alive Time (ms) 30000
Update Sequence 88737
<p>С уважением,<br/>
Денис Ларионов</p>
