I think I finally have all of the shape files loaded into my PostGIS DB.
One question, I get the following notices, are they o.k.?
NOTICE: CREATE TABLE will create implicit sequence "shp:r_gid_seq" for
serial column "shp:r.gid"
NOTICE: CREATE TABLE / PRIMARY KEY will create implicit index
"shp:r_pkey" for table "shp:r"
Also, according to step 5 there is a ZIP file that I need - where do I
get it and what do I need to do with it once I have it?
Finally, can I remove the original VMAP0 data once it has been converted
with the wiki scripts? It takes up a huge amount of hard drive space.
Thanks!
JAB
Yes - these are fine (good infact).
Its too big to put on the wiki page - I'll probably make it available via FTP in a few weeks. If you have an FTP site I can upload the postgresql dumps for you.
I suggest you keep the .zip files (they are just under a gig total) "just in case". Also, unfortunately, ogr2ogr does not always produce topologically correct datasets so you might have to look at the original data.
dave
