[Geoserver-users] WPS and netCDF data
I'm interested in use WPS with netCDF-raster data. Is it possible to do it
actually with GeoServer?
Other question : I have 2.4.1 Geoserver version and I don't have WPS demo
builder in the demo part and apparently this demo builder exist in the 2.4.x
versions. I'm wrong?
Thanks a lot for your help,
Pascal.
View this message in context: http://osgeo-org.1560.x6.nabble.com/WPS-and-netCDF-data-tp5101160.html
Hi Pascal,
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Other question : I have 2.4.1 Geoserver version and I don’t have WPS demo
versions. I’m wrong?
Have you got the WPS extension installed? http://geoserver.org/display/GEOS/GeoServer+2.4.1
Jonathan
Ciao Pascal,
late answer... see below...
Simone Giannecchini
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Fri, Jan 31, 2014 at 11:52 AM, pascal <pascal2833@anonymised.com> wrote:
Generally speaking yes. You need to install the WPS extension as well
as the NetCDF extension.
Mind you the NetCDF extension is available only for recent versions of
GeoServer.
You need to install the WPS extension.
Pascal.
WatchGuard Dimension instantly turns raw network data into actionable
security intelligence. It gives you real-time visual feedback on key
security issues and trends. Skip the complicated setup - simply import
a virtual appliance and go from zero to informed in seconds.
http://pubads.g.doubleclick.net/gampad/clk?id=123612991&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Thanks a lot!
Pascal.
View this message in context: http://osgeo-org.1560.x6.nabble.com/WPS-and-netCDF-data-tp5101160p5103178.html
