[Geoserver-users] WPS DescribeProcess metadata-element in GeoServer
I have created a wps-process and want to add some metadata to the process.
(Not the DataInputs)
With the annotation @DescribeProcess you can specify the title, description
and version of the process. How can I specify some metadata?
Do I have to specify this in de class of the process or do I have to specify
something in the DescribeProcess-class (I haven't found any methods for
setting or getting metadata in the classes ProcessFactory or
ProcessDescriptionType???)
In the DescribeProcess-response, there should be shown the metadata-element
like:
<ProcessDescription>
   <ows:Identifier>...</ows:Identifier>
   *<ows:Metadata xlink:title="geoserver" about="geoserver"/>*
   <DataInputs .../>
   <ProcessOutputs .../>
</ProcessDescription>
Thank you for helping!
View this message in context: http://osgeo-org.1560.x6.nabble.com/WPS-DescribeProcess-metadata-element-in-GeoServer-tp5082811.html
On Thu, Oct 10, 2013 at 11:25 AM, vermesser123 <maxmeier35@anonymised.com> wrote:
specify
There is no notion of process metadata, the process susbsytem is developed
in GeoTools
and is somehow independent from a WPS usage, it's meant to be used as is,
within
desktop, batch or command line tools to.
So, an evolution of the ProcessFactory interfaces, as well as a extension
of the existing
annotations (or new annotations) would be require.
Either that, or develop sub-interfaces that are WPS aware.
You can discuss these evolutions on the developer lists, eventually make a
formal proposals to
change the API, and finally provide a pull request (in this order, if you
go with a pull request
with no previous discussion the community might also end up having to
reject the change).
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I have found a solution:
In the DescribeProcess.java you can create a MetadataType-Object (with
Ows11Factory). Then, you can add it to the ProcessDescriptionType-Object
(....getMetadata().add(...)).
Unfortunately you can only define the attribute "about" and "title" in the
MetadataType-Object.
Do somebody know, how to declare the "xlink:href"-attribute. Normally, the
Metadata-information links to a resource, so this attribute should be
supported?!
I tried it with the MetadataType-Datatype from ows20. But the creation of
the object with Ows20factory.createMetadataType failed (Caused by:
java.lang.IllegalArgumentException: The value 'simple' is invalid.)
View this message in context: http://osgeo-org.1560.x6.nabble.com/WPS-DescribeProcess-metadata-element-in-GeoServer-tp5082811p5085253.html
I think, with the function
MetadataType.getAbstractMetaDataGroup().add(EStructuralFeature feature,
Object value) you can add the href-attribute. But how to create the
EStructuralFeature??
I tried it with loading the EStructuralFeature "href" from the ecore-model
"ows11.ecore"
URI uri = URI.createFileURI(new File("Q:/ows11.ecore").getAbsolutePath());
EcoreResourceFactoryImpl ecoreResourceFactory = new
EcoreResourceFactoryImpl();
Resource ecoreResource = ecoreResourceFactory.createResource(uri);
try {
        ecoreResource.load(Collections.EMPTY_MAP);
     } catch (IOException e) {
     // TODO Auto-generated catch block
  e.printStackTrace();
EList<EObject> elist = ecoreResource.getContents();
EPackageImpl epi = (EPackageImpl)elist.get(0);
EClassImpl ec = (EClassImpl)epi.getEClassifiers().get(0);
EStructuralFeature href = ec.getEStructuralFeatures().get(2);
MetadataType mt = owsf.createMetadataType();
mt.setAbout("tag");
mt.setTitle("titel");
mt.getAbstractMetaDataGroup().add(href, "reference");
I got the error "The feature 'href's type 'null' does not permit a value of
type 'java.lang.String'"
I thought, the EType of href isn't defined.
I loaded the XMLType.ecore in the same way as the ows11.ecore and extracted
the EDataType AnySimpleType. Then I initialized the href's EType with this
value.
Next error: Invalid entry feature 'AbstractReferenceBaseType.href'
Does somebody has an idea (perhaps the right solution???)
View this message in context: http://osgeo-org.1560.x6.nabble.com/WPS-DescribeProcess-metadata-element-in-GeoServer-tp5082811p5086537.html
