[Geoserver-users] WPS error
when I try to run some algorithms (eg. Buffer), after sending data to my server returns this error:
NoApplicableCode
Could not parse XML request. Element type "ogr:N" must be followed by either attribute specifications, ">" or "/>".
A have GeoServer 2.7.0 and WPS extension with Hazelcast.
Where could be the problem?
Thanks
Dominik
On Sun, Apr 26, 2015 at 11:29 PM, Dominik Abrahám <dominikabraham@anonymised.com4...>
wrote:
NoApplicableCode
Could not parse XML request. Element type &quot;ogr:N&quot; must be
followed by either attribute specifications, &quot;&gt;&quot; or
&quot;/&gt;&quot;.
Seems like your server is sending over mailformed xml. Can we have a look
at it to confirm?
Another though, it might be an unflushed buffer on your end, thus,
GeoServer getting only part of the xml it should be receiving.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Oh, sorry. I tried my GeoServer WPS service through QGIS WPS plugin. How can I get xml of the request in this case?
Dominik
2015-04-29 15:11 GMT+02:00 Andrea Aime <andrea.aime@anonymised.com>:
On Wed, Apr 29, 2015 at 2:13 PM, Dominik Abrahám <dominikabraham@anonymised.com> wrote:
Hi, here is address of my GeoServer WPS: http://46.28.111.137:8080/geoserver270/wps
I did not ask for the GeoServer, but for the xml of the WPS request :slight_smile:
Also, please try keep the users mailing list in CC, private support from me is available only to people with contracts
with GeoSolutions
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Apr 29, 2015 at 4:39 PM, Dominik Abrahám <dominikabraham@anonymised.com...>
Hum... I'm not familar with the QGIS WPS Plugin, but you can force
GeoServer to log the request bodies,
see here:
http://docs.geoserver.org/latest/en/user/production/troubleshooting.html#logging-service-requests
Ing. Andrea Aime
@geowolf
Technical Lead
The error message says “could not convert this feature collection to a JTS Geometry”.
It mans you’re trying to feed a list of features to a process that only accepts a single Geometry with no attributes
On Thu, Apr 30, 2015 at 3:12 AM, Dominik Abrahám <dominikabraham@anonymised.com> wrote:
QGIS WPS plugin seems to be not a good choise, it has some problems with character encoding. So I rather tried GeoServer WPS through its own request builder. My GeoServer settings and my testing data (attachment “data”) both have charset UTF-8. But now it returns me another error (attachment “error”).
Dominik
2015-04-29 16:41 GMT+02:00 Andrea Aime <andrea.aime@anonymised.com>:
On Wed, Apr 29, 2015 at 4:39 PM, Dominik Abrahám <dominikabraham@anonymised.com> wrote:
Hum… I’m not familar with the QGIS WPS Plugin, but you can force GeoServer to log the request bodies,
see here:
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
