[Geoserver-users] WPS Execute GET request KVP syntax
I am having a bit of a hard time getting a WPS execution to run through a
GET request as the documentation about the geoserver specifics of this is a
bit sparse.
I want to use the gs:Clip function.
So, as a base I need the following parameters:
* service=wps
* version=1.0.0
* request=execute
* identifier=gs:Clip
Now I struggle with the Data inputs. The features to clip come directly from
a Geoserver layer whereas the clipping features are provided in WKT.
For the internal Geoserver feature I am using a standard WFS getFeature
request. Is there an internal pipeline for achieving the same:
features=@xlink:http://<my-geoserver-host>/geoserve/ows?service=WFS&version=1.0.0&request=GetFeature&typeName=<myLayer>&maxFeatures=50&outputFormat=application%2Fjson
For the WKT polygon I am a bit clueless. I tried:
* clip=<my-WKT-polygon>@mimeType=application/wkt
What am I missing here?
And what other parameters are required?
Thanks in advance
Max
View this message in context: http://osgeo-org.1560.x6.nabble.com/WPS-Execute-GET-request-KVP-syntax-tp5265620.html
You probably need to read the Spec (http://portal.opengeospatial.org/files/?artifact_id=24151) - start around page 38 which covers how to specify and encode your parameters. As for which parameters are needed look at the DescribeProcess response.
Ian
On 10 May 2016 at 16:12, xzam <mail@anonymised.com> wrote:
bit sparse.
  • service=wps
  • version=1.0.0
  • request=execute
  • identifier=gs:Clip
features=@anonymised.com:http:///geoserve/ows?service=WFS&version=1.0.0&request=GetFeature&typeName=&maxFeatures=50&outputFormat=application%2Fjson
  • clip=@mimeType=application/wkt
Thanks in advance
Max
Mobile security can be enabling, not merely restricting. Employees who
bring their own devices (BYOD) to work are irked by the imposition of MDM
restrictions. Mobile Device Manager Plus allows you to control only the
apps on BYO-devices by containerizing them, leaving personal data untouched!
https://ad.doubleclick.net/ddm/clk/304595813;131938128;j
Geoserver-users mailing list
Ian Turton
any experience?
Ian
bit sparse.
  • service=wps
  • version=1.0.0
  • request=execute
features=@xlink:http:///geoserve/ows?service=WFS&version=1.0.0&request=GetFeature&typeName=&maxFeatures=50&outputFormat=application%2Fjson
Thanks in advance
Max
Ian Turton
[https://ad.doubleclick.net/ddm/clk/304595813;131938128;j](https://ad.doubleclick.net/ddm/clk/304595813;131938128;j)
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
Hi Ian,
thanks for the hint. Had a look at the DescribeProcess response and the WPS spec already but couldn’t really get it working based on that.
The spec says:
Complex := InputId “=” Value *( “@” ComplexAttribute )
ComplexAttribute:= ComplexAttributeName “=” Value
ComplexAttributeName := “mimetype” | “encoding” | “schema"
Based on I assumed the syntax for the second parameter would be:
clip=@mimetype=application/wkt.
But that didn’t work unfortunately.
Max
Von: Ian Turton ijturton@anonymised.com
Gesendet: Dienstag, 10. Mai 2016 17:31:47
An: Max Stephan
Cc: geoserver-users
Betreff: Re: [Geoserver-users] WPS Execute GET request KVP syntax
Ian
bit sparse.
  • service=wps
  • version=1.0.0
  • request=execute
Thanks in advance
Max
Ian Turton
On Tue, May 10, 2016 at 6:41 PM, Max Stephan <mail@anonymised.com> wrote:
Hi Ian,
WPS spec already but couldn't really get it working based on that.
I don't have a quick answer, but just as a reference, as far I know WPS 2.0
specification dropped GET request support
altoghether because it resulted too problematic to use for clients and
complicated to reliably implement for servers.
You might also want to check a few examples in the GeoServer own tests,
might point you in the right direction:
https://github.com/geoserver/geoserver/blob/master/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java#L330
Also quite important for this type of request, make sure you are url
encoding all parameters values in your request.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
