[Geoserver-users] WPS Extension doesn't appear to install correctly
When I install the GeoServer WPS extension v2.5.1 as described here the extension does not appear in the Service Capabilities list in GeoServer admin UI and I don’t see any errors in the log. What I do see in the log is:
15 Jul 09:54:41 INFO [org.geoserver] - Loaded service ‘wcs’, enabled
15 Jul 09:54:41 INFO [org.geoserver] - Loaded service ‘wfs’, enabled
15 Jul 09:54:41 INFO [org.geoserver] - Loaded service ‘wms’, enabled
15 Jul 09:54:41 INFO [org.geoserver] - Loaded service ‘WPSInfoImpl-5dbe844d:14737022c46:-8000’, enabled <<<
15 Jul 09:54:48 INFO [geoserver.wps] - Found 48 bindable processes in Geometry processes <<<
15 Jul 09:54:48 INFO [geoserver.wps] - Found 89 bindable processes in Deprecated processes <<<
15 Jul 09:54:48 INFO [geoserver.wps] - Found 29 bindable processes in Vector processes <<<
15 Jul 09:54:48 INFO [geoserver.wps] - Found 4 bindable processes in GeoServer specific processes <<<
15 Jul 09:54:48 INFO [geoserver.wps] - Found 11 bindable processes in Raster processes <<<
The log lines with <<< at end are new since the WPS extension was installed.
I also see there is a “wps.xml” file in the GeoServer “data_dir” with the following contents:
true
WPS
<org.geotools.util.Version>
1.0.0
</org.geotools.util.Version>
false
http://schemas.opengis.net
false
30.0
300
16
16
org.geoserver.wps.DeprecatedProcessFactory
true
org.geoserver.wps.jts.SpringBeanProcessFactory
true
org.geotools.process.geometry.GeometryProcessFactory
true
org.geotools.process.raster.RasterProcessFactory
true
org.geotools.process.vector.VectorProcessFactory
true
I am using GeoServer 2.5.1 on Windows 7 64-bit and using JDK 7.0.54 64-bit. Does anyone know why WPS doesn’t appear to install correctly?
–Steve
I installed on Mac recently and found I had to install the WPS and CWS plugins by hand and unpack them in the right place in the install tree. That was on my home machine so I can’t dig out the details now. IIRC I googled on geoserver install XXX and found pages that had instructions.
R
15 Jul 09:54:41 INFO [org.geoserver] - Loaded service 'wcs', enabled
15 Jul 09:54:41 INFO [org.geoserver] - Loaded service 'wfs', enabled
15 Jul 09:54:41 INFO [org.geoserver] - Loaded service 'wms', enabled
15 Jul 09:54:41 INFO [org.geoserver] - Loaded service 'WPSInfoImpl-5dbe844d:14737022c46:-8000', enabled <<<
<wps>
  <id>WPSInfoImpl-5dbe844d:14737022c46:-8000</id>
  <enabled>true</enabled>
  <name>WPS</name>
  <versions>
      <version>1.0.0</version>
  </versions>
  <citeCompliant>false</citeCompliant>
  <schemaBaseURL>http://schemas.opengis.net</schemaBaseURL>
  <verbose>false</verbose>
  <connectionTimeout>30.0</connectionTimeout>
  <resourceExpirationTimeout>300</resourceExpirationTimeout>
  <maxSynchronousProcesses>16</maxSynchronousProcesses>
  <maxAsynchronousProcesses>16</maxAsynchronousProcesses>
  <processGroups>
    <processGroup>
      <factoryClass>org.geoserver.wps.DeprecatedProcessFactory</factoryClass>
    </processGroup>
    <processGroup>
      <factoryClass>org.geoserver.wps.jts.SpringBeanProcessFactory</factoryClass>
    </processGroup>
    <processGroup>
      <factoryClass>org.geotools.process.geometry.GeometryProcessFactory</factoryClass>
    </processGroup>
    <processGroup>
      <factoryClass>org.geotools.process.raster.RasterProcessFactory</factoryClass>
    </processGroup>
    <processGroup>
      <factoryClass>org.geotools.process.vector.VectorProcessFactory</factoryClass>
    </processGroup>
  </processGroups>
</wps>
--Steve
Want fast and easy access to all the code in your enterprise? Index and
search up to 200,000 lines of code with a free copy of Black Duck
Code Sight - the same software that powers the world's largest code
search on Ohloh, the Black Duck Open Hub! Try it now.
http://p.sf.net/sfu/bds_______________________________________________
Geoserver-users mailing list
Ok, I figured it out, I was just making a dumb mistake by looking at the wrong GeoServer instance as I have several.
--Steve
-----Original Message-----
From: Russell Fulton [mailto:r.fulton@anonymised.com]
Sent: Tuesday, July 15, 2014 1:59 PM
To: Stephen Brooke
Subject: Re: [Geoserver-users] WPS Extension doesn't appear to install correctly
I installed on Mac recently and found I had to install the WPS and CWS plugins by hand and unpack them in the right place in the install tree. That was on my home machine so I can't dig out the details now. IIRC I googled on geoserver install XXX and found pages that had instructions.
R
When I install the GeoServer WPS extension v2.5.1 as described here the extension does not appear in the Service Capabilities list in GeoServer admin UI and I don't see any errors in the log. What I do see in the log is:
'WPSInfoImpl-5dbe844d:14737022c46:-8000', enabled <<< ...
Raster processes <<< ...
I also see there is a "wps.xml" file in the GeoServer "data_dir" with the following contents:
<wps>
  <name>WPS</name>
  <versions>
  </versions>
  <processGroups>
    <processGroup>
    </processGroup>
    <processGroup>
    </processGroup>
    <processGroup>
    </processGroup>
    <processGroup>
    </processGroup>
    <processGroup>
    </processGroup>
  </processGroups>
</wps>
I am using GeoServer 2.5.1 on Windows 7 64-bit and using JDK 7.0.54 64-bit. Does anyone know why WPS doesn't appear to install correctly?
--Steve
-------- Want fast and easy access to all the code in your enterprise?
Index and search up to 200,000 lines of code with a free copy of Black
Duck Code Sight - the same software that powers the world's largest
code search on Ohloh, the Black Duck Open Hub! Try it now.
