I tried several wps processes that return a geojson. The geometry is in the same projection than the input data (could be other than 4326), but the information on projection is not in the geojson so the client application doesn’t know it.
Here is what I read about it
http://geojson.org/geojson-spec.html#named-crs
Should this information be added in the geojson by the process when epsg is not the default?
thanks
steve
doesn't know it.
is not the default?
Yes, that would be a nice addition. Are you interested in working on it?
If memory serves me right the json encoder we use in the geojson module
back in GeoTools,
I can give you further details
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
