[Geoserver-users] WPS outputs
Hello,
I want to define custom outputs for a WPS. I searched through the source code and I found these classes (ProcessParameterIO, ComplexPPIO and other inherited classes), but I didn’t find enough details (For example regarding the constructors parameters). Is there any documentation on that ?
Thanks.
no, GeoServer has basically no programmer documentation, you will have to figure out
how to write a PPIO by looking at the many examples available (and then register it in the
Spring context for it to be picked up).
That said, you are on the right track!
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
I would recommend CSVPPIO (./extension/wps/wps-core/src/main/java/org/geoserver/wps/ppio/CSVPPIO.java) for a simple example of using a datastore to read and write CSV data. You are looking for the decode and encode methods. There is also an associated test class that shows how to use them programmatically.
Ian
Ian Turton
I’ll look into it, thanks a lot !
Ian
On Fri, 26 Nov 2021 at 11:28, Andrea Aime <andrea.aime@anonymised.com949…> wrote:
On Fri, Nov 26, 2021 at 11:16 AM Manele Ait Habouche <manele.ait.habouche@anonymised.com> wrote:
Hello,
Thanks.
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Ian Turton
