[Geoserver-users] WPS plugin support of INSPIRE compliant data from external WFS 2.0
Hello everyone,
currently I am developing some basic WPS and I am testing them on GeoServer
2.7.0.
The next phase involves retrieving some INSPIRE compliant data from an
external WFS 2.0 service.
I would like to know if GeoServer WPS plugin supports them as input.
Thanks in advance.
Matteo
View this message in context: http://osgeo-org.1560.x6.nabble.com/WPS-plugin-support-of-INSPIRE-compliant-data-from-external-WFS-2-0-tp5234418.html
On Wed, Nov 4, 2015 at 11:42 AM, matteo.eccher <matteo.eccher@anonymised.com>
wrote:
Hello everyone,
2.7.0.
So you are talking about complex features? If that's the case, most likely
not, we have the code to encode complex features, but not to parse them.
I believe adding such support would be quite beneficial, but also a
significant
effort coding wise... it could start by only parsing some of the complex
structures and evolve over time though, I don't think anyone would require
it
to parse all types of complex features from day one.
As this would be a new feature, I'd suggest you have a look at this
document:
https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks Andrea for the quick reply.
Yes, I was referring to complex features.
I see, I will have a look at the document.
Matteo
On Wed, Nov 4, 2015 at 12:30 PM, Andrea Aime <andrea.aime@anonymised.com.1107…> wrote:
On Wed, Nov 4, 2015 at 11:42 AM, matteo.eccher <matteo.eccher@anonymised.com> wrote:
Hello everyone,
2.7.0.
So you are talking about complex features? If that’s the case, most likely
I believe adding such support would be quite beneficial, but also a significant
effort coding wise… it could start by only parsing some of the complex
structures and evolve over time though, I don’t think anyone would require it
As this would be a new feature, I’d suggest you have a look at this document:
Ing. Andrea Aime
@geowolf
Technical Lead
Mr Eccher Matteo
Developer
Fondazione Graphitech
Via Alla Cascata, 56/C - 38123 Trento – Italy
Office: +39 0461 283396
Fax: +39 0461 283398
Email: matteo.eccher@graphitech.it
Website: http://www.graphitech.it
Dati Personali - Questo messaggio e i suoi allegati sono indirizzati esclusivamente ai destinatari in intestazione, e/o può contenere informazioni protette e riservate ai sensi della normativa vigente. E’ vietato qualsiasi impiego diverso da quello per cui è stato inviato. Se lo avete ricevuto per errore siete pregati di non inviarlo a terzi, di usarlo per impieghi diversi da quelli per cui è stato inviato, e di archiviare o copiare le informazioni in esso contenute. Siete altresì pregati di eliminarlo in ogni sua parte e di avvisare immediatamente il mittente. Se doveste avere domande, contattaci a to postmaster@anonymised.com.
Confidentiality - This communications and any attachments are intended for the above-named person and are confidential and/or may be also legally privileged. If you are not an intended recipients of this email you must take no action based on it, nor must you disclose the contents to another person, use it for any purpose, or store or copy the information in any medium; please delete/destroy and inform the sender immediately. Should you have any questions, please contact us by replying to postmaster@anonymised.com Internal Virus Database is out of date.
Matteo,
there is support in GeoTools for complex feature parsing in gt-wfs-ng, the new generation WFS client:
https://github.com/geotools/geotools/wiki/complexfeature-parsing-and-building-support
This implementation is intended to do just what you want: consume complex feature services and create Java GeoAPI objects that conform to the information model. I found it to be a bit broken and in need of work. Depending on your information model, it may or may not work for you as is or with a small amount of work.
Historical notes:
https://github.com/geotools/geotools/pull/841
https://osgeo-org.atlassian.net/browse/GEOT-4147
I have never used wfs-ng, but there are some nice examples of parsing complex features in this unit test:
https://github.com/geotools/geotools/blob/master/modules/unsupported/wfs-ng/src/test/java/org/geotools/data/wfs/internal/parsers/XmlComplexFeatureParserTest.java
I tried to get it to work with a real GeoSciML 2 Borehole but ran into problems that suggest the implementation is incomplete:
https://github.com/bencaradocdavies/geotools/commit/9e8d9c22d1f3ddfd0b180f7f53dae17457be9786
https://github.com/bencaradocdavies/geotools/commits/complex-feature-wfs-client-example
Here is my bug report:
[GEOT-5246] Complex feature WFS client fails to parse nested features
https://osgeo-org.atlassian.net/browse/GEOT-5246
See also the off-list discussion below.
Kind regards,
Ben.
-------- Forwarded Message --------
Subject: Re: Complex feature parsing and building in 14.0
Date: Fri, 9 Oct 2015 16:56:41 +1300
To: Jody Garnett <jody.garnett@anonymised.com>
Jody,
tl;dr: no complex feature WFS client announcement for 14.0 as it is b0rked
I just spent most of today trying to get a complex feature WFS client
example working against real services, unfortunately without success. In
addition to some defects such as incorrect handling of maxFeatures,
there appears to be something wrong with the parsing of some nested
features. Some other complex properties appear to work, but the feature
builder chokes when unparsed properties required by the schema are
absent. I suspect that this may be a bit of work to fix. This is an
ambitious piece of work, and perhaps 80-90% there, but not yet done.
I think we will have to ignore this new feature for any 14.0 release
announcement as it is not yet ready for real work.
Kind regards,
Ben.
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
On Wed, Nov 4, 2015 at 1:05 PM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Hi Ben,
I'm wondering... is that stuff hooked up at all?
I did remember the WFS store had some complex feature parsing work, but
seeing that WFSDataStore/WFSFeatureSource
are based on ContentDataStore, and thus limited to simple features only, I
did not bother to check further.
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Ben,
There are WFSDataAccessFactory / WFSContentDataAccess / WFSContentComplexFeatureSource which appear to work but have no test coverage. There is an SPI entry for WFSDataAccessFactory.
Kind regards,
Director
New Zealand
