[Geoserver-users] wps response document: java implementation
I’m working with WPS for about six month.
I made several processes wps whose otuput were all kind rawdata, following the procedure:
  1. make java program with pom.xml and applicationContext.xml, how described in the geoserver guideline
  2. maven install
  3. copy the obtained jar file in the geoserver directory.
Now I would start to create processes wps with output of type xml file, where stored the wanted output but i did not find any description or example to make this.
Thanks a lot for your help.
Lorenzo
