On Wed, Mar 20, 2013 at 1:38 PM, Rodrigo Antonialli
<rcantonialli@anonymised.com> wrote:
Our ideia was to use only the session inside geoserver to control users, and
make the application only to check this session and user roles.
OGC services are stateless, GeoServer won't create a session even if
you authenticate
on OGC services (it will do so only in the GUI).
(For now, the only idea we had was to request a getCapabilities and check
for a specific protected namespace . If the namespace is there, the user is
logged, otherwise, he is not. But we couldn't find a way to check user
roles.).
If you are working inside GeoServer there are two extension points you can look
at in order to implement and declare as beans in the spring context:
* DispatcherCallback, in particular the operationDispatched method, get the
first parameter from the operation, if it is a WPS Execute it will
be a ExecuteType
that you can explore to decide whether to allow or deny the current request
* implement ProcessFilter (maybe just extend ProcessSelector) and
register it as a bean,
and then decide which processes to allow in output based on the current user,
which you can get by using
SecurityContextHolder.getSecurityContext().getAuthentication()
(this is a standard Spring Security call)
Of course there is also the option of modifying directly the service
security, it's just that
after the security subsystem refactor I don't know where it is applied
now, Christian might
provide pointers on that.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
