[Geoserver-users] WPS, WCS demo request builders are not working
I am trying to upgrade our GeoServer to 2.9.0, but have now some problems with WPS and WCS request builders. Also the Demo requests page seems to have similar problems.
The list of all demo pages is shown and also the main demo page shows up, but all the requests fail. I get only the new window with “Loading…” text. After a while it is replaces with Internal Server Error (500) message.
Even if I choose something very trivial like WPS DescribeProcess, so it should not be related to data.
Also the WPS getCapabilities is working fine on front page and even the WPS API itself seems to work, if I simply post the request to appropriate URL.
No error messages come to catalina.out
Some files seem to be created into …/work/Catalina/localhost/geoserver/wicket-filestore/
The link to our GS: http://avoin-test.csc.fi/geoserver/web
I tried also GS 2.8.3, 2.7.1.1 on the same machine and the situation was same.
GS is installed as .war on Tomcat (8.0.32)
One of the tested .war files is working fine on another server.
Changing data_dir to the test data_dir did not make any difference either.
Any ideas, what could cause this?
Best regards,
Kylli Ek
GIS-coordinator
CSC - IT Center for Science Ltd
PL 405, 02101 Espoo
Tel: +358 50 38 12 838
giscoord@anonymised.com
That sounds … scary. We do ask for help testing the beta and release candidates before we make a release.
Trying WCS Builder
  • Tyring it myself, I can get describe coverage (on nurc:Arc_Sample) and GetCoverage XML to work … clicking GetCoverage produces a nurc-Arc_Sample.tif 2.1 MB in size with dimensions 0x0 (so not good).
  • Trying with sf:dem and nurc:mosaic works fine though.
  • WCS is a bit odd in that depending on your browser it may just say “Loading” and then download the file … which you can then preview locally. Changing the output format to a PNG (rather than GeoTIFF) will often let it display in the brows.
I do not have the WPS builder installed to test against.
On 1 June 2016 at 03:04, Kylli Ek <kylli.ek@anonymised.com> wrote:
Best regards,
Kylli Ek
GIS-coordinator
PL 405, 02101 Espoo
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
Geoserver-users mailing list
Jody Garnett
