[Geoserver-users] Wrapper exception
Hello everyone.
Does anybody knows what is the exception below from the wrapper.log?
Thanks
JJ
INFO | jvm 1 | 2015/07/01 15:01:30 | at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 1 | 2015/07/01 15:01:30 | at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 1 | 2015/07/01 15:01:30 | at java.lang.reflect.Method.invoke(Unknown Source)
INFO | jvm 1 | 2015/07/01 15:01:30 | at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:238)
INFO | jvm 1 | 2015/07/01 15:01:30 | at java.lang.Thread.run(Unknown Source)
INFO | jvm 1 | 2015/07/01 15:01:30 | 2015-07-01 15:01:30.614::WARN: EXCEPTION
INFO | jvm 1 | 2015/07/01 15:01:30 | java.net.BindException: Address already in use: bind
INFO | jvm 1 | 2015/07/01 15:01:30 | at sun.nio.ch.Net.bind0(Native Method)
INFO | jvm 1 | 2015/07/01 15:01:30 | at sun.nio.ch.Net.bind(Unknown Source)
INFO | jvm 1 | 2015/07/01 15:01:30 | at sun.nio.ch.ServerSocketChannelImpl.bind(Unknown Source)
INFO | jvm 1 | 2015/07/01 15:01:30 | at sun.nio.ch.ServerSocketAdaptor.bind(Unknown Source)
INFO | jvm 1 | 2015/07/01 15:01:30 | at org.mortbay.jetty.nio.SelectChannelConnector.open(SelectChannelConnector.java:205)
INFO | jvm 1 | 2015/07/01 15:01:30 | at org.mortbay.jetty.nio.SelectChannelConnector.doStart(SelectChannelConnector.java:304)
INFO | jvm 1 | 2015/07/01 15:01:30 | at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39)
INFO | jvm 1 | 2015/07/01 15:01:30 | at org.mortbay.jetty.Server.doStart(Server.java:233)
INFO | jvm 1 | 2015/07/01 15:01:30 | at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:977)
INFO | jvm 1 | 2015/07/01 15:01:30 | at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
INFO | jvm 1 | 2015/07/01 15:01:30 | at org.mortbay.start.Main.invokeMain(Main.java:183)
INFO | jvm 1 | 2015/07/01 15:01:30 | at org.mortbay.start.Main.start(Main.java:497)
INFO | jvm 1 | 2015/07/01 15:01:30 | at org.mortbay.start.Main.main(Main.java:115)
Looks like it is a wrapper allowing a java application to be run as a windows service.
On 1 July 2015 at 15:12, jair santos <jairds@anonymised.com> wrote:
Hello everyone.
Thanks
JJ
Don’t Limit Your Business. Reach for the Cloud.
GigeNET’s Cloud Solutions provide you with the tools and support that
you need to offload your IT needs and focus on growing your business.
Configured For All Businesses. Start Your Cloud Today.
https://www.gigenetcloud.com/
Geoserver-users mailing list
Jody Garnett
On Thu, Jul 2, 2015 at 12:12 AM, jair santos <jairds@anonymised.com> wrote:
Hello everyone.
Thanks
JJ
Source)
EXCEPTION
It means there is already another program running on the same TCP port
(normally that would be 8080, but you can change
it during installation)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
